Gabriel Hi-Jackers
Old May 7, 2008 | 12:21 PM
JOJOECARLO's Avatar
Default Gabriel Hi-Jackers
just got a set for my '86 LS....i know this will improve my ride..because as of now the passenger side shock is kinda blown..i know the LS suspension is soft but i dont think it shoulda been this soft..so i got the gabriels (air shocks) anyone try these out? tryin to look for a product review...
Old May 7, 2008 | 12:44 PM
GrandPaDave's Avatar
Default RE: Gabriel Hi-Jackers
They are very stiff and mostly for towing. Try to keep 25-30 pounds of prressure minimum or you will tear a bladder.
If you want your car to have that hopped-up look, go to 90-100 lbs.
125 lbs. will make the car run very rough.
Old May 7, 2008 | 06:31 PM
mickey's Avatar
those are the only air shocks to have under a monte.
I ran mine between 30 and 35 in then all the time. If i was goign to the track i would run up to 50 to allow for more room for the slicks to expand.
but you cna look at the side of the car on level ground and have a frend help you put them to the level ya want .
Also when you first get them in DO NOT DRIVE WITH OUT ANY AIR IN THEM AT ALL.
use a bike pump etc... something to get a bit of presure in them it will prevent the bladder from becomming pinched or tore on the way to the station to ge tthem where ya want them for driving.
JaxJim
May 6, 2010 02:05 PM
