Front suspension noise
Noise in front suspension & steering 2006 SS. Clunking noise when accelerating, also when turning left or right.Can be felt in steering wheel. Lower front control arm bushings have been replaced due to one being installed upside down during assembly.Did not eliminate noise. Car has 27000 miles. I purchased it new This problem has just recently started . Anyone have similar problem? Thanks
Sway bar end links. ;)
CV Axle?
The cv axles usually last around 50k or 100k
Originally Posted by Facekicker
(Post 573377)
CV Axle?
The steering intermediate shaft needs to be lubricated or replaced.
Originally Posted by 03SSLE
(Post 573424)
Glad to hear you got your problem solved :)
Originally Posted by Eugene Leamer
(Post 573742)
Thanks for responding. This is the problem. The noise is in the column under the dash. Did not realize this until I could not hear noise out side of car or under the hood. All other possibilities were checked and eliminated. Thanks again.
What in the column would make that kind of noise?
