Dual Brake Calipers
I'm thinking about adding a hydro e-brake, and was wondering if anyone knows where to find a dual brake caliper adapter.
They do not exist for this platform. If you're serious about one, you should go to an engineering / fab shop. It's not difficult to design / build, but it would have to be a custom designed one off and will likely be fairly expensive. I'd be suprised if you could do the setup for under a grand.
Just curious, why a hydro ebrake? I get it on a RWD drift car, but I don't see the use on a FWD car. |
(Post 714635)
Originally Posted by WolvenScout
(Post 714732)
For me it would be half function, half looks. The function would be for drag racing. Locking up the rear wheels for the burnout,
Before you spend a butt ton of money on useless add ons for drag racing, I'd strongly suggest getting engine/trans built and actually run it. If you're really running it, you'll have plenty to spend your money on between tires and trans rebuilds. and where I'll mount the two step button. The looks half is it'll be a nice addition to the "race car" look I want. (roll cage, bucket seats, harness, etc.) |
There is one 'race car look' mod I would suggest, and that's gutting the car. Take out all of the unnecessary stuff - radio, AC, backseats, etc will help it go faster for drag racing. The side benefit is that it'll also help the trans stay alive longer too.
(Post 714735)
They came from the factory with an ebrake that'll hold the car just fine. If you really must have a hydraulic option you can activate with a button, just install a line lock kit on the existing brakes.
(Post 714735)
(Post 714735)
I'd also reccomend against doing 'race car stuff' for looks, especially on a street car. I'm especially against a roll cage on the street ever. You get in a serious wreck and smash your bare head on that steel tube and it's over. Unless you plan on driving to the store with your helmet on....
(Post 714735)
(Post 714741)
It might just be the brakes and rotors on the car, but my ebrake doesn't hold very well. It especially wouldn't hold during a WOT burnout. I'm also talking about a lever style hydro ebrake, that uses a cylinder and brake fluid.
The factory ebrake, if properly functioning, will lock the rear wheels 100%. If your problem is dragging the locked wheels, then a hydro brake won't help that. I just might do that. I really like the safety of a roll cage, regardless of where the cars driven. Cause you can see tons of videos of people who aren't even driving fast or recklessly, just getting hit, and their vehicle rolls over, crushing the cabin. Sure it'll keep the roof intact, but if you've rolled it that hard to smash the roof in, you WILL smack your head on the bar, and you will die. This has been proven numerous times - cages are for track cars only. |
(Post 714759)
Just fix the ebrake. To me that sounds like saying your engine doesn't work well, so you're going to swap another engine onto the rear wheels.
(Post 714759)
The only way it is safe to drive with a full cage is with a helmet. If you're going to wear your helmet driving on the street to the grocery store, then that's fine. But driving with a cage and no helmet is MORE DANGEROUS.
(Post 714761)
Yeah, obviously I plan on replacing the brakes before doing any of this. As for just using the ebrake, I want the car to look cool, and a hydro brake would make a good addition to the interior. It'll also be fun to install and use.
I'd think this would kinda be a detractor from looks having a drift brake setup on a FWD car that can't actually drift, but of course that's just personal opinion. I'm not disputing the fact that using a cage without a helmet is dangerous. I know that it is. A roll cage is just something I want in the vehicle, for safety, and looks. Like the above, I'd also personally think this would be a big detractor to looks. I'd imagine you'd get a lot of laughs climbing out of a caged 11 or 12 second street car with your helmet on at Walmart or something. If it's mostly for race car looks anyways, I'd probably just do a chute instead. A lot more visual impact without being such a giant pain for street driving. |
(Post 714789)
