cv drive shafts. what brand?
Old May 24, 2017 | 12:41 PM
hamerhead's Avatar
Default cv drive shafts. what brand?
I am in the process of replacing most of the front suspension on my 2004 SS, due to a lot of rust. car came from Ill. What brand of half shafts are best?summit has cardone and so does rock auto. price is around $50. at rock auto acdelco has them for around $500. for the pair. I want to do it once and do it right. Thanks
Old May 24, 2017 | 11:42 PM
I'm currently having the same issues with my cv axles. Was told by the very reputable (The Driveshaft Shop) to get the A/C/ Delco brand. But ONLY from a reputable dealer as there are knock off A'C Delco parts floating about. So I'm getting mine from a dealership, should be in tomorrow. Mine are about $675 for a left and a right. yeowsa...
Old May 25, 2017 | 04:33 AM
l67ss's Avatar
X2 on acdelco
Old May 25, 2017 | 09:00 AM
hamerhead's Avatar
Thanks, I would like to use oem shafts but they cannot be found for the SS supercharged . I have researched ebay, google with no results for the SS S/C models. just after market
Old May 25, 2017 | 10:58 AM
I recently redid them on my monte. I picked up some used stock shafts off a lower mileage gtp from a local junkyard (granted I have hybrid shafts with the 5th gen monte outermost portions).
I had a Napa shaft in the drivers side that was giving me problems. Seems like the aftermarket stuff doesnt have the quality metal or heat treat process that OEM does.
So I just took the used stock shafts, put in new boots and grease and it seems to be good so far.
