Another rearend question.....
Old Dec 30, 2009 | 07:07 AM
78monteman's Avatar
Default Another rearend question.....
I have come across a 8.5 posi rearend out of a Grand National. The only problem is that it needs axles and backing plates. Does anyone know if I can swap the axles and backing plates out of my 78 Monte, or do I have to go with actual Grand National axles? Are they bigger or do they have more splines?
Old Dec 30, 2009 | 11:05 AM
Budsjlm's Avatar
well if i remeber right the 7.5 10 bolt rear end has like 27 splines and the 8.5 10 bolt has i wanna say 32 but that doesnt sound right i know they are different
Old Dec 30, 2009 | 11:08 AM
Budsjlm's Avatar
what i did to find out is go to summit put in each car and look at the rearend stuff
Old Dec 31, 2009 | 08:13 AM
sideways's Avatar
Know the backing plates are the same, axles should be . Think they are both 28 spline, some of the early 7.5 ones may be 26 ,but cant remember for sure.
Old Dec 31, 2009 | 09:42 AM
78monteman's Avatar
I think I figured it out. The Grand Nationals came with a 8.5 that had 28 spline axles. The 78 Montes came with a 7.5 but the axles were only 26 splines, so I will have to buy new axles. I wish iwould have kept my other rearend, I could have used the backing plates off that one, instead of my original rearend. Thanks for all the help.
Old Dec 31, 2009 | 09:52 AM
78monteman's Avatar
I just spoke to the guy that has the rearend. It has 3.42 gears and is a posi, and he wants $400 for it, but it doesn't have axles or backing plates. Does that sound good or what?
Old Dec 31, 2009 | 10:43 AM
Budsjlm's Avatar
400 for a housing and a diff... doesn't sound too bad but you'll have to spend some more $ to get it going
Old Dec 31, 2009 | 12:18 PM
sideways's Avatar
Ya, I would snag it up in a heartbeat. still have less then 600.00 in a 8.5! good deal.
Old Dec 31, 2009 | 04:19 PM
TheMonteMan's Avatar
its a good deal but you could pick up a 28 spline carrier and axles for your current rear. the down fall would be that it still only has a 7.5 ring gear and there really isnt a point to throw money into it.
Old Jan 1, 2010 | 09:39 PM
2000MonteCarloRwd's Avatar
Yea, what he said....
Then you wont have to remove the axle from the car and no brake plate transplants.
It depends on what your using it for.... A street car? Are slicks ever gonna be used? Small or big block & power/ torque rating.
