adaptors
Old Sep 7, 2007 | 09:44 AM
jay26's Avatar
Default adaptors
does anyone have any insight on these,like how they would ride?looking for a wider stance
http://cgi.ebay.com/ebaymotors/WHEEL...QQcmdZViewItem
Old Sep 8, 2007 | 07:13 AM
wiz kidd's Avatar
Default RE: adaptors
usually those are just for converting your hubs over to a different bolt pattern so you can put different wheels on that you like....i guess if you got the same bolt pattern to the same one, they would just in sense make the wheels stick out further...i dont know if i'd suggest that though, because you'd have to deal with rubbing probably
Old Sep 8, 2007 | 07:52 AM
jay26's Avatar
thats all i want is for them to stick out a little more than the stock look,for winter time.i might purchase them in a month or so.see how they work!
Old Oct 10, 2007 | 07:26 PM
wheelguy's Avatar
Depending on how much farther you're looking to kick them out, you could also go with a 1/4 inch spacer. It doesnt sound like alot but it is noticable. If you do go with the 1 inch adaptor make sure you buy some real short 12 x 1.5 lugs to hold them on because most open ended lugs won't sit low enough as to allow the wheel to sit flush on the adaptor, most standerd adaptors are 1 1/4 inches.
