99z34 tire choices
Old Jun 7, 2011 | 08:47 AM
BlownUptoHigh's Avatar
Default 99z34 tire choices
Stock tires are 225 60 r16. Was thinking about getting some indy 500 tires but they only have 225 55 16 is it a big deal lowering the sidewall? Also if i wanted to run wider tires would i look for 235 60 16 options or something else?
Old Jun 7, 2011 | 12:20 PM
Boxman420's Avatar
you could run a 55 profile. it wouldnt make much of a difference. you will just have a smaller looking tire which may look weird at first. and yes 235 would be a little wider. but sometimes if you go from a 60 to a 55 profile it will be a little wider but only by about .2-.4 inches or so.
Old Jun 7, 2011 | 01:18 PM
I would try not to stray too far from the overall diameter of the tire so that your speedometer still reads correctly.
Old Jun 8, 2011 | 08:33 AM
Boxman420's Avatar
^yes i forgot about that. iknow my spedo is off by a little bit. but here is a little calculator that is pretty cool.
Tire size calculator
Old Jun 8, 2011 | 10:59 AM
Here's a comparision with the link u provided
Specification Sidewall Radius Diameter Circumference Revs/Mile Difference
225/60-16 5.3in 13.3in 26.6in 83.7in 757 0.0%
225/55-16 4.9in 12.9in 25.7in 80.9in 783 -3.3%
Does that mean im gaining gas mileage with the smaller tire?
Old Jun 8, 2011 | 11:17 AM
Your gas mileage is not going to change. The cars tires will be doing more RPMs because the overall circumference is smaller.
The readings show that your speedo will be 3.3% off, and you will be going slower than the speedometer says.
monte carlo 3831
Nov 29, 2011 09:07 PM
BlownUptoHigh
Sep 10, 2011 06:06 AM
77gp
May 15, 2011 12:05 PM
kicker
Apr 26, 2010 03:31 PM
smolek37k
Jan 5, 2008 12:49 AM
