22's without lift?
Old Jan 25, 2012 | 09:51 PM
I like the look of 20's but I'm unsure of the 24's. Maybe without a lift it would look ok. But I am not a fan of lift's on anything but a 4 wheel drive truck.
Old Jan 25, 2012 | 11:00 PM
No bigger than 20s, im a fan of big rims ive got 22s on my Edge but its a bigger vehicle, montes dont look good with huge rims imo 20s or 18s
Old Jan 26, 2012 | 12:12 AM
DuSSt's Avatar
I would stick to 20 or smaller as well, totally up to you if you can make bigger work, but the smaller tire you have to use will also sacrifice a lot in the ride of the vehicle, will be a lot rougher.
01 Monte SS's Avatar
X2... No need for all that extra ground clearance in a front wheel drive car. Not like your gonna go offloading and put the clearance to use. Just my opinion.
Old Jan 27, 2012 | 01:55 PM
oamos's Avatar
22s will fit a MC...I have 22s in the pic below....Wat I did to mine...I lifted the springs in the back so it would damage my back tires. the tire size 245/30/22 or 255/30/22...either tire size will fit...I'm going to go with 24s this year on mine and wont have to cut it. All I can say is...Take care of ya car cause it can cause a lil problems with ya Axle but its no biggy...axles are running about 69.99 a piece so GO FOR IT HOMIE
Old Feb 14, 2012 | 08:04 PM
03 on 22s's Avatar
22s fit on mine only rub very little when turning or no lift just new suspension all the way around
Old May 24, 2013 | 01:14 PM
PhillyMonteCarlo's Avatar
Quick question, sorry for using your thread on this but... I'm interested in a set of 20inch rims i saw and they are 5x114.3 20x10 would they fit my 2002 monte carlo ss and what size tire should i get for them?
Old May 24, 2013 | 02:10 PM
Boxman420's Avatar
as far as i know 10inch wide wheels dont fit.. they might depending on the offset. but i have 22x9.5 and they fit.. they rub in the front when i do fulls turns though
Old May 24, 2013 | 02:17 PM
Oh okay gotcha thanks
Old Jun 3, 2013 | 01:58 PM
rgjr702's Avatar
i roll on 245/30/22 no problems at all with no lift but my tires dont stick out. im putting a 1 inch spacer in and lifting like 1 inch.
