07 lt bad suspension
Old Sep 16, 2009 | 05:55 PM
mak330's Avatar
Default 07 lt bad suspension
Hi has anyone with an 06 ,07 monte carlo had any problems with a harsh ride which may be partially the bad roads that i drive on but also a thud with every bump thats hit. Its still under bumper to bumper warranty for another month. So if theres a commen problem id like to hear about it thanks
Old Sep 16, 2009 | 06:02 PM
mak330's Avatar
Its almost like the car is bottoming out and always gets stable quick but theres a clunking noise that just doesnt seem right
Old Sep 16, 2009 | 06:11 PM
mak330's Avatar
It also shakes pretty bad when i hit the brakes whiel going 60+
Old Sep 16, 2009 | 06:21 PM
03Monte's Avatar
if it's still under warranty, take it to the dealer to have it checked out. your ride should not be as harsh as you describe (unless your hitting massive pot holes..)
what part of Ohio are you in?
Old Sep 16, 2009 | 06:24 PM
mak330's Avatar
Akron ive been reading other posts and i think it might be the mounts
Old Sep 17, 2009 | 12:48 AM
God_Bot's Avatar
Could be the engine mounts, could also be a loose suspension piece. Whatever it is I'd say take it in to the dealer.
Man I wish I still had my warranty...
Old Sep 17, 2009 | 12:54 AM
03Monte's Avatar
the roads are pretty bad in Akron, im in Dayton but i used to drive as far as Youngstown weekly...
like i said, and the other members; Definitely take it to the shop!
Old Sep 17, 2009 | 11:35 AM
sonin66's Avatar
most def take it to the shop. it does sound like mounts are causing noise but also have them check your tie rods. my were bad i think after the first year and a half
Old Sep 17, 2009 | 03:15 PM
MAMONTE's Avatar
Yea, take it to the dealer and get it fixed under warrenty....
The shaking while braking sounds like your Rotors, which will not be covered under warrenty...OEM rotors warp easily.
Old Sep 20, 2009 | 09:09 PM
mak330's Avatar
thank you for the advice i am very busy right now with getting a house and my baby girl, but ill try to get to the dealer and nice add on the rotors i took off the tire the other day on bothe fronts and measured with mics there within 4 thou so i dont think its that but ill ask
