trunk lid lock removal
Old Apr 8, 2012 | 05:12 PM
bblackstone's Avatar
Default trunk lid lock removal
I want to romove not work around the trunk lid lock. Then put it back. Any suggestions?
Old Apr 8, 2012 | 05:21 PM
What year is it?
Old Apr 8, 2012 | 05:45 PM
Default 2004
Originally Posted by 03jgmonte
what year is it?
2004...............
Old Apr 8, 2012 | 05:48 PM
Open the trunk & at the bottom directly under the lock cylinder there is a plate with a rivit, drill the rivit out & remove the plate & u can pull the lock cylinder out
Old Apr 8, 2012 | 05:55 PM
And when i want to lput back the cylinder. How do i go about replacing the plate that has the rivit in it? Could i just use a larger self tap screw or a nut bolt? Seems to me popping that rivit will do nothing for me. Its just a plate. A bumper or buffer. The rivited plate has nothing to do with the cylinder. If i can reach the cylinder through that hole why not directlt from in side the panel itself.?
Old Apr 8, 2012 | 06:11 PM
The plate has forks that go up & hold the cylinder in & just put a new rivit in when u wanna put it back in
Old Apr 9, 2012 | 12:45 AM
Default thanks
yep thanks. Instead of drilling out the rivit i took a wedge fork and popped it out. The whole rivit. When i was done replacing the unit back together i just took a forming hammer and popped it back in. Tapped the metal back down. Looks like it was never removed. Thanks again. This topic can be deleted.
DerrtyD
Apr 26, 2013 11:49 AM
Epic
Aug 13, 2007 07:06 PM
EJFX
Apr 3, 2007 08:42 PM
montejass
May 25, 2005 05:37 AM
