6th Gen ('00-'05): Roof Moulding
Old Feb 23, 2016 | 10:10 AM
mkenney's Avatar
Default Roof Moulding
Has anyone had a problem with the rubber roof moulding strip in the slot for a roof rack coming loose? Can that go back with a little adhesive or should it snap in place? It doesn't seem to want to sit in the groove. It almost seems a bit long as it bulges up in the middle. I don't want it to fly away on the freeway. Has anyone fixed that before? Tips would be appreciated.
Old Feb 23, 2016 | 12:47 PM
butch049's Avatar
Had the same problem on my 2002 I pulled it all out cleaned the groves real good.at Oreillys they have strips of moulding in the body supply section I got the carbin fiber look fit perfect little gule and tape it comes with works perfect and looks much better. You can look on Oreills web site look for carbin fiber moulding Ill get a part number when I go back to work.
Old Feb 23, 2016 | 12:51 PM
mkenney's Avatar
Thanks!
Old Feb 23, 2016 | 12:53 PM
butch049's Avatar
found the part number Line AVD S37200 go in and ask for that 12 feet enough for both sides let me if you try it
Old Mar 16, 2016 | 04:08 PM
mkenney's Avatar
Hey Butch049, the local O'Riellys was out of trim piece so I bought the two sided tape and repaired the trim piece I had. Thanks for the tip just the same.
