removing valve covers and intake maifold
Old Mar 23, 2010 | 10:41 PM
Default removing valve covers and intake maifold
Okay I was just reading somone painted their intake manifold and I just didnt want to steal his thread soooooo, can someone please give me detailed instructions on how to remove my valve covers and intake manifold??
Im wanting to paint them both.. Also could you give me your opinion on what color to paint them.
Im leaning towards chrome, but im open to suggestions, or definatly if you have pics or links to pics on a 3400 (If you didnt know what engine I had) that would be most appreciated. Thanks all!!!
Old Mar 24, 2010 | 01:35 AM
I know you said paint, but I absolutely LOVE a mirror polished upper intake on a 3100/3400. Unfortunately, I can't find a pic on google images- but it looks baller and way better than paint IMO.
Old Mar 24, 2010 | 08:43 AM
yeah thats what im looking for, the mirror finish.
but do you know how to remove these??
Old Mar 24, 2010 | 08:25 PM
ok LOL nobody wants to help me here... and what happened to the guy who got banned here with the HID lights comming on to me LOL
Old Mar 24, 2010 | 09:37 PM
Justin Knight's Avatar
pulling the upper intake off a 3.4 litre is soooooo easy i wouldn't bother with the valve covers though. you need a 10mm and a 13mm socket and a ratchet and a 13mm wrench, some needle nose pliers a small screw driver and a battery wrench. you will also need a new upper intake gasket (get a felpro gasket they are the best).
1. disconnect the battery ground
2. remove the alternator harness and main wire(use the 13mm wrench to hold the alternator post and use the ratchet to loosen the nut)
3. remove alternator support rods if it has them
4. remove the intake hose from the throttle body
5. disconnect all wiring harness connectors carefully (they are easy to break) from the tps, iat, map, idle air control motor, egr, and evap purge solenoid. if i missed any that are attached to the upper intake...sorry
6. remove the pcv tube(easier to remove the pcv with it)
7. loosen the 10mm bolts and remove the map sensor and vacuum hose
8. you may need to loosen but not remove the lower bolts holding the coil pack and ignition module bracket
8.5. remove egr valve
9. disconnect the park plug wires from the coil packs for the front spark plugs and drape them over the front of the rad support
10. remove remaining bolts from upper intake and pull it off
11. remove the old gasket whilst not dropping any down the intake runners
12. POLISH THAT THING LIKE CRAZY
13. enjoy
if i missed anything i apologize that was from memory only and i'm kinda drunk right now.
Old Mar 24, 2010 | 09:55 PM
mak330's Avatar
do you vibrate it to get that mirror finish. i would think polishing it would lead to rust. or are you talking about chrome.
or high temo chome paint
Old Mar 24, 2010 | 10:50 PM
thank you!!!!!!!!
Old Mar 25, 2010 | 07:16 PM
superrod29's Avatar
he said it all man... great instructions bro! and yes im going with a ble and black/white theme... u should go with black and red, u know black intake manifold and red lettering... ill look for a pic heres one thats black with yellow lettering... just picture it with red or yellow lettering...
Old Mar 25, 2010 | 07:25 PM
superrod29's Avatar
heres mine... i think u were talkin about me painting those... it took me about a total of maybee10 - 12 hours... and overnight so i could let the paint dry...
Old Mar 25, 2010 | 09:39 PM
yes i was talking about you, man those two look great guys!!
