interior mod
the handles were quire easy, they just bolt togeather with a bracket on the opposite side.
the total proccess is this:
1. wash part (i use dawn dishsoap)
2.wipe with tack cloth
3. coat with adhesion promoter (let dry..20 minutes or so, you dont want it to dry completely)
4. 3 light coats of dye, and 2 medium coats. (let dry, i waited 2 days for the dye to set properly)
5. 3 light coats of low luster clear (you can use high gloss if you wish), then 2 medium coats of clear.
6. let it sit and cure for at least 4 days, otherwise you may scratch the dye before it can set...
i haven't done the bottom part (like the pic enzo linked), im not sure that's what i want...
enzo, thanks for that pic, you are making it easier to decide if i want that route or not...
I bought extra pieces, that have been sitting in my closet for almost 3 months now. So waiting for it to dry won't be a problem :P
Check out this video, it show the steps and how easy it is.
(the guy in the video does not do the adhesion promoter, i do recommend you do this, it will help ensure the dye sticks and does not chip off!)
edit: helps if i link the video huh...
http://www.youtube.com/watch?v=2mMYl2sW0Zw
Yes, thanks for the link too. I'm going to have to do mine in the future also, the "paint" that's on mine is coming off and just looks nasty! Hope I can find a donor car for a console swap before I do it.
if your console was painted with actual paint, you will not be able to dye it...well, you can but it wont last.
the paint clogs the pores of the plastics making it virtually imposable for the dye to make a strong bond..
I like what you guys have done/are doing with the two tone interior.
That's something I've wanted to do with my Monte since I got it. To break up the monotone black interior. But haven't worked up the ambition to start pulling my interior apart. Especially since I need it as my daily driver. Probably end up getting junkyard pieces and swap them out when they're ready for installation.
Brock, have you considered maybe painting the screw head in the door handle shroud to match the silver? What you have now looks great, but the black screw head kinda draws your eye.
