How to Paint my new Body Kit ?
Old Aug 6, 2011 | 05:16 AM
2004_montecarlo_supercharged's Avatar
Question How to Paint my new Body Kit ?
Hi everyone! I'm new here and I just got my bodykit and i need to know how to paint it and what kind of paint i need to paint. I have a Silver car and yes! I want to paint it Silver.. Thank You for your time to read this boys/gals!
Last edited by Space; Aug 6, 2011 at 06:17 AM. Reason: To post more infor in Topic : ) 2 get attention : )
Old Aug 6, 2011 | 06:16 AM
Hi Keith & Welcome to the Monte Carlo Family..
What type of body kit did you get ?
Check back later to see `if any of our expert painter's post on your question..
Until then you may want to check out the below infor
how to paint a body kit - Google Search
Click above link to check out several sites on painting body kits...
We hope you take some B-4 & after pictures & share : )
Good Luck on your Project..
Hows the weather in Alaska ?
Old Aug 6, 2011 | 06:21 AM
mrl390's Avatar
What kind of kit did you get? Is it plastic or fiberglass?
Old Aug 6, 2011 | 02:43 PM
HI GUYS! Yes! I got the pictures of my body kit on my profile now.... and it's a Fiberglass
Old Aug 6, 2011 | 03:33 PM
BlackRainSS's Avatar
Welcome to the forum!
Old Aug 6, 2011 | 04:03 PM
mrl390's Avatar
My advice would be to go over the whole cover and sand/fix any spots that arent perfect. Being fiberglass it wont be completely smooth. Im assuming there is primer or gel coat on the pieces. You will want to sand them down smooth with some 320 grit paper. Its a good idea to use some 2k primer surfacer. Once the surfacer is dry you need to sand it down with some 400 then 600 grit. I would do 220 grit dry to cut the orange peel and then 400 wet to take the 220 scratches out. Finish it off with 600 grit. From there you can seal it but its not necessary. Then base/clear to finish it off.
Old Aug 7, 2011 | 05:30 AM
Thank You Monte 04 Ls....
Matt,
But I can color it on the same color as my car right?...
Old Aug 7, 2011 | 09:51 AM
mrl390's Avatar
You just need to find the paint code for your car and use the same color so it matches.
Old Aug 7, 2011 | 11:54 AM
xxtheshockerxx's Avatar
RED DEVIL
you can find the code on the inside of the trunk lid. IIRC it will say BC/CC then the code.
Old Aug 7, 2011 | 01:35 PM
Glad to see you finally made it over, is it bumpers or extensions? If extensions id fill all the imperfections prime paint and a few good layers of clear and you should be good.
