front license plate bracket
Old Jun 28, 2010 | 05:01 PM
2001cincymonte's Avatar
Default front license plate bracket
I have recently purchased a 2001 Monte SS that was registered in Kentucky where they do not have front license plates. Here in Ohio, we have them, and I need to find out how to mount the front plate. There is a cover panel on the bumper, and when I remove it there isn't any type of bracket for the plate. Is there a special bracket I need to buy, or can I just use the two small holes the the cover panel was attached with to mount the plate? Any help someone has is greatly appreciated.
Thanks.
Old Jun 28, 2010 | 05:06 PM
Montelicious's Avatar
I am interested in purchasing the piece/filler you took off, please! I need one! You just put your license plate in the 2 holes in the bumper.
Lisa
Old Jun 28, 2010 | 05:12 PM
My Monte is black, don't know if that is the color you need. The two holes that hold the cover plate on seem too small to be for a license plate though. I will need to check the position to see if that will work, sure hope it does. If you are interested in the black cover I have, let me know.
Old Jun 28, 2010 | 05:14 PM
Black is great! And yes I would like it. I will send you my email address. The holes should line up.
Lisa
Old Jun 28, 2010 | 05:41 PM
Thanks! and welcome to the forum! I look forward to getting the piece! I just replied to your email you sent me.
Lisa
Old Jun 28, 2010 | 06:25 PM
The plate just bolts on the bottom with 2 bolts and there is a slit that you slide the plate up into to hold the top in place.
Old Jun 28, 2010 | 06:29 PM
Jomao_o's Avatar
Welcome
Lisa congrats on your filler!
Old Jun 28, 2010 | 06:30 PM
Thanks Jose!
Old Jun 29, 2010 | 04:47 PM
I just checked, and the holes used for the filler piece do not match with the holes on a license plate. However, there are two small indents in the bumper material that do line up with a plate. Is it okay to just make a hole with a screw in these indents to attach the plate? It seems like there should be a more secure way to attach the plate. Anyone using a front plate now? It would be great to hear how someone has attached theirs.
Thanks, shoup.
Old Jun 29, 2010 | 08:36 PM
Yes you have to drill out the holes with a small drill bit and use license plate bolts with a tapered end to secure the plate. Like I said earlier the top of the plate slides up into a slit at the top and it's very secure - the plate isn't going anywhere!
