Finished cleaning Monte undercarriage.
It looks REALLY nice! Keep an eye on that rubberized undercoating, as I've heard it has big tendency to flake off in a year or so. If it does and you end up re-doing this effort, look into a system called POR15. They had modified their instructions over the years.
Basically, get rid of any chipping/flaking pieces of debris, apply a "metal prep" product (DO NOT appliy any body fillers or primers, the closest you can get to bare metal the better, but if you have solid paint, don't worry about it, the POR15 will protect the paint), follow it's instructions, then you can spray or bruch paint the POR15 on the surface (anything I've done with POR15 was brush painted). If you spray it, you MUST use their paint thinner to keep the rust inhibiting properties. After the POR15 is applied they recommend top coating it if it will be exposed to UV light.
Just food for thought. Hopefully the rubberized undercoating you used is better then what I've heard of. Time will tell, but awesome job, it gives your Monte a "clean" look under neath!
I understand what you are saying about the undercoating flaking off. Have heard about this issue before. So I hopefully really cleaned everything well enough for a proper bond. And also bought a Professional grade coating, not the low cost product. Keep my fingers crossed, did my wheel wells last year and they actually still looked very nice, but shot them again anyway....
Looks Good i coated mine with rinoliner
Ha Ha I was actually looking at the Rhino liner products. Great choice, just no spray on products and I wanted to get every nook and cranny, seam, so I thought I had a better chance with a aerosol. How is yours holding up?? Bet it still looks very nice.
Looks really nice. I was just under mine and it looks a lot better then I thought it would. I do have a little rust on the a arms and front suspension parts but thats it. I suprised too after 6 michigan winters.
__________________
Glad to know the factory undercoatings actually are doing your Monte's underside nicely!! Cool!!
__________________
I used the spray on that the dealers use it looked great when it was first done but sence i live on gravel it got really dirty looking lol, ill prob clean it up once the GTO is off the lift & respray my exhaust & everything
Have you guys heard about the spray on under-liner actually being worse than no protection at all? I've heard that it will actually trap moisture and make it rust faster than before. Any comments on that?
I'd really like to at least re-shoot my wheel wells with some to make them look better and 'blacken them up'
Chevy actually applies a waxy type undercoating to the underside of our cars, but it wears off in a few years, then the control arms, sway bars etc. are just painted and they start to rust. galvanized metal and chemical baths are only used on selected body parts, as good as it is, other areas will rust...So might as well be pro-active and stave off the rust if possible...
![](http://i280.photobucket.com/albums/kk165/02MONTE/CAR%20PICTURES%20FOR%20MONTE%20FORUM/GerstmannUpperMontebelly073.jpg)
