driver/passenger window gaping
Old Jul 20, 2011 | 08:20 PM
FinalSS's Avatar
Default driver/passenger window gaping
I don't know if I am posting this in the right section or not, but I just wanted to know how do I fix the problem of my windows don't role all the way up and are super slow going up and down especially the passenger window?
Old Jul 20, 2011 | 09:29 PM
Mike 00LS's Avatar
It's probably coming off the track - it just needs to be adjusted (the glass that is).
Old Jul 20, 2011 | 09:52 PM
FinalSS's Avatar
thanks man, is there a certain way to adjust it or like a diy or take it to a shop?
Old Jul 21, 2011 | 04:37 PM
Mike 00LS's Avatar
Remove your door panel, locate whatever track/feet the window came out of, using urethane glue/sealant for auto glass, reaffix window into said track/feet after thoroughly cleaning all parts of old adhesive. Be sure to carefully operate the window to check position before it sets. Leave the window closed - don't operate it - for several days to set thoroughly. If you are not fairly confident of your ability to position the glass correctly in the track/feet, you will do well to take it to a professional.
Old Jul 24, 2011 | 07:39 AM
FinalSS's Avatar
Thanks for the info. I'm definitely taking it to a pro.
Jester_20
Apr 6, 2013 03:53 PM
STUMPMI
Apr 5, 2013 03:38 AM
FinalSS
Jul 20, 2011 08:12 PM
Jordanshedd5
Feb 14, 2011 01:24 PM
indytruder
Feb 15, 2009 03:50 PM
