Door to Quarter Panel Interference
2004 SS
Within the last couple days my drivers door and front quarter panel rub each other when I open the door. They rub, then they make a little "pop" sound when they slip past each other. I didn't hit anything, and nothing looks out of place. Any suggestions? Anything on the door hinges I can tighten? |
I would check your door hinges they may be bad..
With your door open lift it up and see if you have play in the hinge pin. |
If door hinges are OK and nothing has been hit or fender is not loose then why?
Where is it rubbing? My 06 on passenger side at bottom of door was rubbing just a little bit when I first bought it all I did was pull out the fender so the door can clear the fender. EDIT: I pulled out the fender at the bottom and yes mine was doing a "pop" noise as well. All I did was take one of my plastic interior trim tools and used the door to pry on and "forced" the fender out more than where I wanted it to be because it will come in a bit |
1 Attachment(s)
I actually took the time yesterday to clean the ol' girl up. Too much salt and dirt was making it hard to see. It actually looks like the quarter panel is what shifted. The door hinge pins were good. When I tug and pull on the panels, it feels like the quarter panel needs to move forward to be clear of the door. Does anyone know if there's a shim or something that's supposed to be behind one of the fasteners to keep the panel in place?
Well this sucks. My fender rusted away from the bottom of the hinge pillar. There's two bolts that hold the fender onto the pillar and my fender completely rusted through and broke free of the pillar so now the fender is shifted aft and into the door. Looks like I can get a replacement fender for around $50. Hopefully painting won't be awful then I can just swap it out.
Damn you Midwestern weather!!!! |
mines used to do the exact same thing. what i did to fix the problem is to slightly bend the fender, its not a professional fix, but there isnt any noticeable gap between door and fender, and there is no pop, so good enough for me
Originally Posted by owens91
(Post 680696)
used a flat tip screwdriver, placed a couple inches between the lower rocker panel and just put a meesley bit of muscle into it
My concern would be to preserve the door. Until you get the fender fixed and the door continues to POP you may be doing damage to the front of the door.
If it were mine I would look for any decent metal (if any?) and maybe pop rivet or screws with a piece of strapping and secure the fender for now. I would try and keep it out of sight and find a spot to attach to the car itself. |
Originally Posted by montedd
(Post 680722)
