Depo Headlights for my 2006
Old May 14, 2012 | 01:54 PM
Slugger088's Avatar
Monte of the Month -- August 2013
Default Depo Headlights for my 2006
Hi all:
Quick question for those who might have the Depo headlights for the 06-07 model.
I purchased the black housing units and the install was fairly simple. I was able to adjust the low beams just fine but with the high beams I was not so lucky. From what I can tell, the high beams cannot be adjusted. My passenger high bear is fine but the driver's side high beam is shooting way up. Has anyone else had this problem or know of any fixes? I don't use my high beams that much so it's not that big of a deal but its annoying nonetheless.
Is this just the housing causing this? Because I'm assuming the stock unit cannot be adjusted either yet the beam is fine with those.
Another small problem was a bit of condensation inside the lights the first two nights I had them in. I read that this sometimes happens and will go away. I hope its not because these are cheaply made, I did everything right.
Old May 14, 2012 | 04:24 PM
I believe the high beam moves with the low beam, or at least it does in my car.
Condensation may be from a little water or something left from the building process, I would say if it's still there in a week or two I would contact the company you bought them from.
Old May 15, 2012 | 11:41 AM
Slugger088's Avatar
When I was adjusting the low beam, the high beam stayed the same. So i am almost 100 percent sure that it cannot be adjusted. Anyone else know?
Thanks though trewyn, ill keep an eye out for anymore condensation.
PhoenixAZMC
May 29, 2012 01:43 AM
77gp
Mar 24, 2011 05:43 PM
