Adding fog lights
Old Aug 1, 2011 | 09:36 PM
Randdady's Avatar
Default Adding fog lights
Alright, so those little cheap things they put in the ls bumpers instead of actual fog lights? Yah, well, one fell out on me (hit a bird) and the other is pretty close.. Just wondering what were some suggestions on fog lights I should put in there and where I would get them. Also, if anyone knows exactly how and where I can wire them up, that would be appreciated as well.
Old Aug 1, 2011 | 09:57 PM
i got the original fog lights and brackets from an ss monte, they didn't program the original switch to work with the ecu tho so i wired mine to a rocker switch, you may want to do the same, the fog lights will be hard to find so you may be better off with just putting a normal fog light kit from any store, just measure to make sure they'll fit, and theres a bumper support behind the cover that you can mount the aftermarket to pretty easily
Old Aug 1, 2011 | 10:23 PM
tremayne0126's Avatar
Check this out let me know if ths help
https://montecarloforum.com/forum/pr...es-sale-29821/
Old Aug 1, 2011 | 11:41 PM
Enzo354's Avatar
STILL SLOW
Buy those ones.^^ Trying to mount a universal kit without brackets is really crappy.
Old Aug 2, 2011 | 12:04 AM
Oh I forgot about those! Franks a great guy price and That's an awesome price!
Old Aug 2, 2011 | 12:13 AM
Thanks to Tremayne for the find. lol J/K
but yea with my 2002 LS it didnt come with foglights just the vents so i cut the vents off and i had to steal foglights with the brackets from a junk yard i didnt have the switch so i just wired them to my lowbeams and upped the fuse :-)
Old Aug 2, 2011 | 09:32 AM
Mike 00LS's Avatar
https://montecarloforum.com/forum/pri...es-sale-2982
Originally Posted by Enzo354
Buy those ones.^^
Those have already been bought. In fact I just got them about 10 minutes ago
Old Aug 2, 2011 | 12:50 PM
Old Aug 2, 2011 | 01:56 PM
Randdady's Avatar
Mogwog, your lucky to have those now haha. I just looked at them and now ill have to pay double for them! But I guess it will do. So how does the bracket mount on my bumper? There is quite a lot more there than I imagined. And I will most likely wire them into an aux fuse and have a rocker switch for them.
Old Aug 2, 2011 | 04:09 PM
Mike 00LS's Avatar
It took me a minute to figure it out, but there's a small piece coming from the side of the bumper that the clip attaches to. Then if you look at the hole in the bumper where the fogs go, you'll see a hole. You just pop a screw through that and it will go into the hole on the assembly. Then the long arm just rests on the bumper to keep it straight. I tried going from the bottom of the bumper but it's a lot easier to just remove the headlight. It's two clips that hold the housing on and a harness on the back. The passenger side one is harder to get inside with because there's a couple things in the way but with some care you can get around it all.
