6th Gen Lighting..
Old Jul 5, 2011 | 09:25 PM
wIcKeDmOtNe's Avatar
Default 6th Gen Lighting..
I was wondering if the back up lights on my 01 monte are the lights on each side of the lisence plate? Has anyone change there bulbs? I want to switch them over to super white lights. I took out both bulbs today and wiped the bulbs clean, i just dont know how to go about replace the bulbs because they dont pull out like most other bulbs..
Old Jul 5, 2011 | 09:36 PM
Boxman420's Avatar
yes they are.. once you have those off you just twist the piece on the back that holds the bulb. and then you can pull the bulb out and put your new ones in, they may need some force.. i had to use needle nose pliers to get one out
Old Jul 5, 2011 | 09:46 PM
They pull out
Back-Up Light Bulb
2001 Chevrolet Monte Carlo
Part Number: LMP BP921LL
Product Line: NAPA Lamps
Attributes: Bulb Base Type : Miniature Wedge (W2.1X9.5D)
Miniature Bulb Candle Power Rating : 21
Miniature Bulb Type : T-5
Overall Diameter : 15.8
Overall Length : 37.9
Volts : 12.8
Old Jul 6, 2011 | 06:13 AM
I changed mine to a superbright because I blacked out my reverse housings.
They are just a pain to replace because they seal pretty well
Old Jul 9, 2011 | 12:10 PM
Excellent. They do seem like they are sealed very well. I know the bulbs in the rearview mirror were also a pain in the **** to pull out.
Another question.. How do i take out my lisense plate bulb? Is it the two nuts?
Old Jul 10, 2011 | 09:38 AM
Boxman420's Avatar
yes if you look above the licence plate there is 2 little nuts. un-screw them to get to the back where the bulb is. i changed ALL of my lights its just been a while
Old Jul 10, 2011 | 09:49 AM
just the two screws, dont expect to put a led bulb in there tho, it wont fit in most cases, they're either too wide or too long and dont fit the housing
Old Jul 10, 2011 | 02:21 PM
BigPana's Avatar
Thanks for this info !
Old Jul 11, 2011 | 05:26 PM
What type of bulbs did you put in your housing? Ill go take a look at mine and see what i can figure out.
Old Jul 11, 2011 | 09:13 PM
Boxman420's Avatar
x2 on what trewyn said. i put a flat 4 smd led in mine and is atleast twice as bright as my stock lights. and mine are blue. anything around 4smd should work. mine is smaller then the OEM bulb
