6th Gen ('00-'05): 100% stock custom headlights
Old Jul 15, 2015 | 12:10 PM
bowtiebandit23's Avatar
Default 100% stock custom headlights
in the process of making custom LED ring 6th gen headlights. not willing to spend $150+ for aftermarket ones. i know this is a shot in the dark, but does anyone know the circumference of the opening inside the headlight around the bulb housing? i dont have a spare set of headlights to open up and check.
Old Jul 15, 2015 | 09:27 PM
Not sure, but you could do it the math way. Measure the diameter and then multiply it by pi.
Old Jul 16, 2015 | 09:41 AM
im trying to find the info without having to separate my head lights multiple times lol. its my DD so trying to do this once and only once
Old Jul 16, 2015 | 10:46 AM
Just measure across the lens to get the diameter of the circle and then divide that by pi. It won't be exact but it should give you a pretty good idea.
Old Jul 16, 2015 | 11:22 AM
yeah i guess i can do that. was looking more for the diameter closes to the inside of housing where the hole for bulb insert is but ill wing it
Old Jul 16, 2015 | 11:33 AM
When I get home I will try to measure the one I have sitting in my closet.
Old Jul 16, 2015 | 01:18 PM
that would be extremely helpful thank you
Old Jul 16, 2015 | 06:18 PM
Diameter of each is 1 1/4 inch (1.25) so circumference is 3.925 inches
Old Jul 17, 2015 | 06:31 AM
is that for the DRL and low beam openings?
Old Jul 17, 2015 | 07:17 AM
That is for both clear lights and the yellow turn signal bulb openings. All three openings are the same size but they look like they aren't
