00-05 monte carlo front nose emblem?
Old 09-13-2009 | 11:21 PM
SLAB_Ryder's Avatar
Default 00-05 monte carlo front nose emblem?
anybody know how to get the nose emblem off of the 00-05 monte carlo? i know you need to take it off for the SLP grill and the tony stewart grill (which im pissed its a stick on) but how do you take it off? please help
thank you in advance
Old 09-13-2009 | 11:32 PM
hmm, well, i've heard some adhesive remover on it first then maybe use a body filler applicator to lift it up, be careful and just remove it very slowly! also a piece of string behind it and you just slowly move it under the emblem to remove? i'm sure more members will be able to offer their help tomorrow due to the fact it is so late! goodluck with it and be careful removing it, see ya
Old 09-14-2009 | 09:00 AM
1FastMonteCarloLT's Avatar
I use a product called Kleen-Strip's Aircraft Decal & Adhesive Remover and get a long piece of fishing line and slowly rock back and forth behind the emblem. It will probably break a few times hence the whole "Use a long piece* lol. Should work
Old 09-14-2009 | 10:39 AM
nemesis's Avatar
2009 Monte Of The Year
very easy to make off. the badge is held by double side tape. take a thin flat head screw driver and wrap the head with paper tower or cloth so you won't scratch your paint. stick the screw driver under the badge and pry out.
Old 09-14-2009 | 07:48 PM
Are you going to have to re-install it? Repainting the car? It doesn't hurt to give those methods a try. But if you're leaving it off, why worry about it.
I'm removing mine in the spring when I put my SLP grill on. I'm not going to worry about saving the knight's crest, simply because it's not looking so good anymore anyway. Weather damaged.
Old 09-14-2009 | 07:53 PM
superrod29's Avatar
same here taz... im doin the same...
Old 09-14-2009 | 11:11 PM
SLAB_Ryder's Avatar
i'm removing it either for the SLP grill or replacing it with a cadillac emblem from an 06 escalade
Old 10-17-2009 | 12:25 PM
Ramairetransam's Avatar
where the hell do i get a new nose emblem ?????
Old 10-17-2009 | 03:08 PM
nemesis's Avatar
if you talking about this nose badge or any custom one you want done email matt at
reflectiveconcepts.com
Old 10-18-2009 | 08:57 AM
Im assuming you took your stock one off and then this one in its place . Any place to get a factory one?But i will check out the link and probably end up getting one there but any placefor a stocker.
Quick Reply: 00-05 monte carlo front nose emblem?
