will it ever be warm again?
RE: will it ever be warm again?
I'm suffering too, but I have an everyday car so Monte is in storage - I MISS MY MONTE!!! I too try an wash my everyday car outside in the cold, but I don't do it unless it's around freezing. I can't get monte out of storage until all the snow melts and we have one good rain to wash all the salt away - god knows when that will be!!!
Global warming is freezing the earth because of all the ice melting all of the oceans get colder which makes for stronger storms and higher water levels around the earth
about clay baring i have never fully understood what you do i have read some of the other post about it but i still dont get what you do with it
use all over the car? or do you just use it a certain problem areas?
it was minus 20 degrees celcuis here today...thats minus 42 feronheight!!! thats crazy cold...but then its supposed to be plus 9 celcius (50 feronheight) on saturday...so that should be good can't wait!! good day to clean car
ORIGINAL: 2000_BLACK_SS
You use it all over the car because clay bar actually removes paint contaminants that are typically invisible to the eye. It will not repair the finish, just remove contaminants. After you've done this the finish should be pretty much just the paint, nothing else. This gives you a smooth finish to start the waxing process with. Once you're done, then you use glaze, which helps fill out any imperfections in the paint. Then wax over the glaze, to give the deepest shine.
ORIGINAL: wiz kidd
This Saturday is going up to 52. I have been realy lucky keeping my 06 Monteclean this winter. It is garage kept and it makes a big difference. My 99 Lumina LTZ how ever needs the washing this weekend.
Haven't tried the sunroof yet
