Where Should i put my fog lights
Old Dec 17, 2012 | 03:54 PM
tps221's Avatar
Question Where Should i put my fog lights
After driving back to school from the pats game last night in the snow. well my dad is buying me round blue tinted fogs as i asked now im thinking about where to place them and what to wire them to. I like the idea of placing them where the emblem was and wiring them to the side markers. or in the lower air intake. opinions? and does anyone know how to remove the chrome mustache on the hood I messed it up with clearcoat.
Old Dec 17, 2012 | 04:05 PM
03SSLE's Avatar
I don't have any advice as far as mounting the lights goes, but you'll never get them to work wiring them through the sidemarker lamps. The lights need a circuit made of larger gauge wire (like 12 gauge) that's wired through a relay because of the amperage requirement to operate them. Most lights come with a switch kit, but if yours don't buy one or have someone experienced with installation of lighting assist you.
Old Dec 17, 2012 | 04:11 PM
tps221's Avatar
so basically to the battery with a switch would be easiest?
Old Dec 17, 2012 | 04:15 PM
Well heres where i put mine, they're mounted underneath the bumper.
Old Dec 17, 2012 | 04:26 PM
01 Monte SS's Avatar
They look good mounted there I say mount them somewhere similar to Keane's!
Old Dec 17, 2012 | 04:27 PM
tps221's Avatar
are yours just tapped into the low beam i was thinking side marker because it stays on with high beam bu ti suppose i dont need them for high.
Old Dec 17, 2012 | 05:13 PM
zzapultimate's Avatar
When I had fogs I mounted them the same place as Keane's.
Also like Mike said, you'll need a relay wired in with a switch. You can use your side lamps to trigger the relay so they come on whenever the side lamps are on, or if you want a little more freedom as to when the come on and off I'd wire the relay up to a switch and pull a signal from some accessory wire.
We should be able to help you wire up a relay if you need help
Old Dec 17, 2012 | 05:17 PM
Wire them up to a separate rock switch, you'll like the ability to have them on when the lows aren't on and vise versa.
Old Dec 17, 2012 | 05:53 PM
tps221's Avatar
seeing as getting to the battery is a pain in the *** to get to can i connect it to the aux port somehow. the oone you jump the car from or jump another car
Old Dec 17, 2012 | 06:08 PM
You should jump the car from the battery itself, anything else and you risk melting wiring.
I would do it directly from the battery itself honestly. If that's not possible run it off the fuse box, but make sure you put in an inline fuse. You could also run it from the AUX fuse in the door fuse panels if needed, but you'd still have to run the wires to the fog lights.
