Snow Removal
Old 01-17-2013 | 07:26 AM
03SSLE's Avatar
In some States it is illegal to leave the snow on the vehicle. As it melts it falls off the car and presents itself as a driving hazard. Have you ever been behind someone when the entire section of snow decides to side off their trunk or roof? The rubber squeegee/water hose works well and doesn't do any damage to the finish. Use the squeegee to remove the majority of snow, then hose the rest off the windows and body. As Jen mentioned, the snow comes off without scratching or damaging the finish.
Old 01-17-2013 | 08:03 AM
Remove the snow however you want. Driving in the winter is going to add more scratches than removing snow in your driveway. Every spring just make a big effort to get a good clay, compound, polish, sealant, wax and then keep up on it.
Typically I use a very delicate brush to remove 90%, then I let the sun do the rest. I don't scrape or scrub an area, if it doesn't come off in light brushing, then it stays for now.
Old 01-17-2013 | 08:29 AM
Thanks mike and mike, come spring i'll have to learn detailing tips. For now i was thinking of wraping a snow brush in a microfiber towel.
Old 01-17-2013 | 08:44 AM
You can do everything that you can, come spring you'll have a ton of fine-scratches in the clear anyway.
But luckily, you can remove all of that
Old 01-17-2013 | 09:58 AM
If thats the case i might as well just keep using my brush as gently as i can like i have been
Old 01-18-2013 | 10:15 AM
my neighbor has a "sno broom" and he swears by it, says it dosin't scratch like a broom does. i need to pick one up for myself.
I just see that taking any dirt/salt that's on the car, under the snow, and scraping it against or into the clear coat.
I agree with Mike. Anything that moves across the paint is going to create fine scratches in the clear if the car isn't totally clean, and in the winter that's never.
Old 01-18-2013 | 03:43 PM
I usually lightly brush my off too. If any snow is frozen to the car it stays on till its thawed enough to come off on its own
God_Bot
03-25-2008 05:03 PM
04 Intimidator
02-17-2008 07:40 PM
BeachBumMike
02-17-2008 10:08 AM
BloodAndHonor
07-29-2007 11:28 AM
jeffsmonte
03-09-2007 02:29 PM
Quick Reply: Snow Removal
