? ? ? Reality check on car-care myths ? ? ?
Old Oct 22, 2009 | 04:15 AM
Lightbulb ? ? ? Reality check on car-care myths ? ? ?
By Consumer Reports
To paraphrase Mark Twain, it's not what you don't know that can come back to bite you; it's what you know for sure that ain't true. When it comes to maintaining your car, misconceptions abound. And even the best intentions can lead you to spend more money than necessary or even compromise your safety. Here are common myths that can do more harm than good:
Myth: Engine oil should be changed every 3,000 miles.
Reality: Despite what oil companies and quick-lube shops often claim, it's usually not necessary. Stick to the service intervals in your car's owner's manual. Under normal driving conditions, most vehicles are designed to go 7,500 miles or more between oil changes. Changing oil more often doesn't hurt the engine, but it can cost you a lot of extra money. Automakers often recommend 3,000-mile intervals for severe driving conditions, such as constant stop-and-go driving, frequent trailer-towing, mountainous terrain, or dusty conditions.
Myth: Inflate tires to the pressure shown on the tire's sidewall.
Reality: The pounds-per-square-inch figure on the side of the tire is the maximum pressure that the tire can safely hold, not the automaker's recommended pressure, which provides the best balance of braking, handling, gas mileage, and ride comfort. That figure is usually found on a doorjamb sticker, in the glove box, or on the fuel-filler door. Perform a monthly pressure check when tires are cold or after the car has been parked for a few hours.
Myth: If the brake fluid is low, topping it off will fix the problem.
Reality: As brake pads wear, the level in the brake-fluid reservoir drops a bit. That helps you monitor brake wear. If the fluid level drops to or below the Low mark on the reservoir, then either your brakes are worn out or fluid is leaking. Either way, get the brake system serviced immediately. You should also get a routine brake inspection when you rotate the tires, about every 6,000 to 7,000 miles.
Myth: If regular-grade fuel is good, premium must be better.
Reality: Most vehicles run just fine on regular-grade (87 octane) fuel. Using premium in these cars won't hurt, but it won't improve performance, either. A higher-octane number simply means that the fuel is less prone to pre-ignition problems, so it's often specified for hotter running, high-compression engines. So if your car is designed for 87-octane fuel, don't waste money on premium.
Myth: Flush the coolant with every oil change.
Reality: Radiator coolant doesn't need to be replaced very often. Most owner's manuals recommend changing the coolant every five years or 60,000 miles. Of course, if the level in the coolant reservoir is chronically low, check for a leak and get service as soon as possible.
Myth: After a jump-start, your car will soon recharge the battery.
Reality: It could take hours of driving to restore a battery's full charge, especially in the winter. That's because power accessories, such as heated seats, draw so much electricity that in some cars the alternator has little left over to recharge a run-down battery. A "load test" at a service station can determine whether the battery can still hold a charge. If so, some hours on a battery charger might be needed to revive the battery to its full potential.
Myth: Let your engine warm up for several minutes before driving.
Reality: That might have been good advice for yesteryear's cars but is less so today. Modern engines warm up more quickly when they're driven. And the sooner they warm up, the sooner they reach maximum efficiency and deliver the best fuel economy and performance. But don't rev the engine high over the first few miles while it's warming up.
Myth: A dealership must perform regular maintenance to keep your car's factory warranty valid.
Reality: As long as the maintenance items specified in the vehicle owner's manual are performed on schedule, the work can be done at any auto-repair shop. If you're knowledgeable, you can even do the work yourself. Just keep accurate records and receipts to back you up in case of a warranty dispute on a future repair.
Myth: Dishwashing and laundry detergents make a good car wash.
Reality: Detergent can strip off a car's wax finish. Instead, use a car-wash liquid, which is formulated to clean without removing wax.
MCF Family Member's, Add the car/care myths that you know `ok..
Do you agree with above article ? Yes ? No ? Post your comments/thoughts...Share cause U care
Old Oct 22, 2009 | 04:45 AM
Thumbs up Share, cause U care : ) `ok
74 Car Care Tips To Keep Your Automobile in Top-Notch Condition
The ultimate auto care guide.
Operating Your Car
We've compiled our best expert advice, surprising tricks, and maintenance and fix-it tips to prolong the life of your car!
1. Be patient during the break-in period
You've bought your dream car and now you want to make it last at long as possible in top condition. Here are some things to remember as you pull it out of the dealer's lot:
During the break-in period, typically the first 1,000 miles (1,600 km), keep your speed under 55 mph (88 kpm) or to the speed recommended by your car's manufacturer.
Avoid heavy loads on the drive train, such as towing trailers, and loading the roof rack or trunk with heavy construction materials.
Do not allow your new car to idle for long periods -- this is good advice for the life of your car, but especially during breakin. The oil pressure generated by doing so may not be sending oil to every part of your engine.
Use only light to medium acceleration, keeping the engine rpms below 3,000 for the first few hours of driving.
2. Drive with care everyday
Being car considerate shouldn't stop after the break-in. Drive with care every day and your car will reward you with longer intervals without repair. Do not race your car's engine during start-up.This is a quick way to add years of wear to your engine, especially if it's cold outside.
Accelerate slowly when you begin your drive.The most wear to the engine and drive train occurs in the first ten to twenty minutes of operation.
Warming the engine by letting it idle in the driveway is not a smart idea.The engine doesn't operate at its peak temperature, resulting in incomplete fuel combustion, soot deposits on cylinder walls, oil contamination, and ultimately damaged components.
Put less strain on your engine and automatic transmission by shifting to neutral at red lights. Otherwise, the engine is still working to push the car even while it's stopped.
Avoid driving at high speeds and accelerating quickly, especially when it's very hot or very cold outside. Such driving behavior will result in more frequent repairs.
Extend the life of your tires with careful driving. Observe posted speed limits. Avoid fast starts, stops, and turns. Avoid potholes and objects on the road. Don't run over curbs or hit the tire against the curb when parking. And, of course, don't burn rubber.
When turning your steering wheel, don't hold it in an extreme right or left position for more than a few seconds. Doing so can damage the power-steering pump.
Consolidate your short driving trips. Most of the wear and tear -- as well as the pollution your car generates -- takes place in the first few minutes of driving. Doing several errands at once, during low traffic hours if possible, will keep your engine happier longer.
3. Buy gas at reputable service stations
Ask whether the gas you buy is filtered at the pump and if the station has a policy about changing the pump filters regularly. If you get a song and dance, find another gas station. Some stations don't have pump filters, making you more vulnerable to dirty gasoline. Other stations may not mix alcohol and fuel properly -- or worse, water down their product. Find a station you trust and stick to it.
4. Don't fill up if you see the tanker
If you happen to see a gasoline tanker filling the tanks at your local gas station, come back another day or go to a different station. As the station's underground tanks are being filled, the turbulence can stir up sediment. Sediment in your gas can clog fuel filters and fuel injectors, causing poor performance and possibly necessitating repairs.
5. Go easy when you're stuck
When stuck in mud or snow, don't make the problem worse by damaging an expensive component. Gently rocking in an attempt to free the car is fine. But if it looks as though you're really stuck, don't keep at it. Throwing your car from forward to reverse repeatedly, as well as spinning tires at high speeds, can generate lots of heat and spell trouble for transmissions, clutches, and differentials. It may be cheaper in the long run to call the tow truck rather than risk big repair bills down the road. It's a good idea to carry a traction aid in the trunk, such as sand, gravel, or cat litter.
6. Lighten up your key chain
Does your car key share a chain with a dozen or more other keys? That's a pretty heavy load hanging off the car key when it's in the ignition.The weight, combined with bouncing while you drive, can wear out the tumblers inside the ignition and eventually lead to ignition switch failure.To add years of service to your ignition switch, purchase a lightweight key chain that allows you to separate your ignition key from the others. Drive with only the ignition key in your ignition. If your ignition key "sticks" when you try to turn on the car, it's a warning that your ignition switch is about to fail. Replace it before you get stranded.
7. Choose a good car insurer
Sometimes, no matter how careful you are, disaster inevitably strikes -- typically in the form of an accident. Make sure that your car will be repaired to the best possible standard by finding an insurer that will pay for parts from the original manufacturer and guarantee the repairs it authorizes.
8. Keep an auto log
Keep a pad and pencil in the glove compartment and use them to record your gas fill-ups and mileage. If you notice that your gas mileage worsens, mention it to your service man. It may be an early warning sign that something is wrong with your car.
9. Preserve your car during long-term storage
If you are not going to use your car for more than a month, store it properly to prevent unnecessary damage and repairs upon your return.
  • Fill the gas tank to help prevent condensation from accumulating in the gas tank. Add a fuel stabilizer and drive the car around a bit to distribute the additive to engine parts.
  • Wash and wax the car thoroughly to protect the finish.
  • Place a vapor barrier on your garage floor. A 4-mil polyethylene drop cloth will do.
  • Disengage the parking brake to help avoid brake corrosion.
  • Put the car on jack stands to take the weight of the vehicle off the wheels and tires.
  • Disconnect and remove the battery to keep it from draining. Place the battery on a trickletype charger. Or periodically drain the battery, using a small light bulb, and then recharge it with a low-volt charger.
  • Plug the tailpipe with a rag to prevent moist air from infiltrating into it.
http://www.rd.com/your-america-inspi...le28223-1.html
Old Oct 22, 2009 | 08:15 AM
skylark65's Avatar
i have a good one, on saturdays ill listen to a program they run on the collage radio station if im up early, its a call-in show for automotive questions, its a blast to listen to, & try to diagnose the problems people have with their cars. one women called in, to prove a point to her boyfriend: the B/F thought that when a headlight bulb went bad in his car, he should change BOTH bulbs.... idk why, lol. they told her to tell her B/F he was a moron, lol, he should just save his $ and change em as needed.
Old Oct 22, 2009 | 08:54 AM
I ALWAYS change both bulbs at the same time. This way I'm less prone to driving again with just 1 headlight, or sometimes the new one will out-shine the old one and that would just look funny
Old Oct 22, 2009 | 09:10 AM
skylark65's Avatar
hmmm, foot in mouth on my part, lol. at least you have good reasoning behind why you change em both, mike. the guy on the radio's reason was something really stupied, i just cant remember for the life of me what it was, lol.
Old Oct 22, 2009 | 09:40 AM
Plus they come 2 in a pack. And I'd probably lose the other one or break it anyway :P
Old Oct 22, 2009 | 12:06 PM
rj's Avatar
rj
Good advice here.
A new bulb will shine brighter then an old one will.
Also, the bulbs get dirt on them even in a sealed headlight. You can take the old bulb out and clean it off and it will be brighter then before. But the new bulb will still out shine it.
So sure, I change them in pairs if I have the cash.
Old Oct 23, 2009 | 09:12 PM
Jomao_o's Avatar
Wow, is this true?
I go out in the mornings to start the car, come back in; drink coffee, watch news, and brush up , and head out about 10 minutes later.
So does this mean that i car go out and start it up without having to let it warm up , just as long as i take it easy on the pedal for the first few miles??? :-?
Old Oct 26, 2009 | 10:02 AM
Hell I will always allow my car to warm-up when it's cold. I don't want to put the stress of driving my vehicle before the oil gets thin and moves well.
Old Oct 26, 2009 | 10:05 AM
Jomao_o's Avatar
I should keep doing the routine of warming it up then huh?
the only problem with that is, during the winter, that's how many vehicles are stolen lol
