mickey and matt
ORIGINAL: mickey
then you going to have to find out where it is at mostlikly unde rthe hood or behind the love box etc...
Behind the WHAT??? LMAO.
![Big Grin](https://montecarloforum.com/forum/images/smilies/biggrin.gif)
I know...typo. Everyone makes mistakes. Sorry, but it's still funny though.
I was waiting until Chris solved the problem before posting this.
hey SCC24540, i am currently going to school for HVAC Service Tech. and your problem sounds more like an electrical issue rather than a leaky hose. i don't believe a leak in the vacuum hose would cause your ac to go from blowing air through the vents then to the floor. i will look into this more for you, but for now try turning the car on, have the vent control set to blow through the vents, then turn it to blow onto the floor. see if you can hear a contact close. the dampers should be shutting to the vents so the air can move across the floor. if you get no results, or it acts normal, then rev the engine while in park and see if it does it again. if it does i believe you have a bad contactor. when you rev you get more current, more current on a bad contactor can cause arcing. i feel that when you accelerate the contactor contacts arc causing them to temporarily close, which will then close the vent dampers, and open the floor dampers. thus air moving through the floor. i hope this helps, again i will look into your problem and try to find out more info.
hey bro thanks for the input but its fixed, it was a vacuum leak. the diaphram behind the front bumper had a broken line. replaced and fixed. but i will def come to u in the future for problems
glad to hear ya found it .
I knew it was a vac. leak it was a matter of where on that model monte.
when this happens it is almost 99.9% of the time it is a vac leak someplace in that system. to allow it to stay in that position .
its painful to get back to where it messed up this last time. no way in hell im gonna do that again. ill just pay some poor sucker like you to get stuck and bleed to change a vacuum hose
