key less remote ?
Old Sep 26, 2012 | 12:57 PM
Ricks 2006 SS's Avatar
Default key less remote ?
OK. Both of my wife's Cobalt keyless entry key fobs do not work at all. The dealer is Nuts on his prices for two of them. Has anyone on here dealt with a place on line or other pesonally ? I'd like to make sure of a place that someone has used before. Thanks Rick
Old Sep 26, 2012 | 04:39 PM
DE02Carlo's Avatar
I bought a couple off ebay that worked and were fairly cheap. Odd both would go bad. Did you have the dealer test them?
Old Sep 26, 2012 | 04:47 PM
cartunes...and mickeyshores....I had to replace 2 of them on my monte...
Lemme guess.. the dealer wants so much..getting a car alarm instahled would be cheaper!
Old Sep 26, 2012 | 04:54 PM
Budsjlm's Avatar
Rick get the numbers off the back of the remote, i may be able to hook you up, got a bag of them,
Old Sep 26, 2012 | 06:39 PM
Okay, I'll ask the obvious question. Are the batteries dead? Or have you replaced the batteries recently? Maybe they need to go through a relearn?
Old Sep 26, 2012 | 06:41 PM
I've run into alot of remote issues, what has been happening is the bracket that holds the batter comes loose from the board. If you're good with a sodering iron, re connect it back to the board, that fixed ours.
Old Sep 26, 2012 | 07:50 PM
I had a loose solder joint on mine too. Other than that there isnt much more in there.
Old Sep 26, 2012 | 08:32 PM
monte06ltz's Avatar
ebay is wear i got mine for like $12 and i took it to the dealer to have programed for i think like $65 cause i had remote start on mine
Old Sep 26, 2012 | 09:33 PM
YUP! Thanks guys I took it to a dealer while we were in AZ this last winter. Said they were junk. WEld broke on both of them. KEYLESS wants $ 98.00 for two for them. About 50% off dealer price. Justin I'll send you a pm when I get the #. Thanks
Old Sep 26, 2012 | 09:37 PM
Justin: Just sent you a E mail with the #'s Thanks
