Higher Octane Gas = Better Performance +MPG
Old Jul 31, 2013 | 08:26 AM
Slugger088's Avatar
Monte of the Month -- August 2013
Unless your engine is knocking, buying higher octane gasoline is a waste of money. Premium gas costs 15 to 20 cents per gallon more than regular. That can add up to $100 or more a year in extra costs. Studies indicate that altogether, drivers may be spending hundreds of millions of dollars each year for higher octane gas than they need.
It may seem like buying higher octane “premium” gas is like giving your car a treat, or boosting its performance. But take note: the recommended gasoline for most cars is regular octane. In fact, in most cases, using a higher octane gasoline than your owner's manual recommends offers absolutely no benefit. It won't make your car perform better, go faster, get better mileage, or run cleaner. Your best bet: listen to your owner's manual.
The only time you might need to switch to a higher octane level is if your car engine knocks when you use the recommended fuel. This happens to a small percentage of cars."
What do you put in your car?
Old Jul 31, 2013 | 10:46 AM
93, but premium is reccomened in our cars
Old Jul 31, 2013 | 03:56 PM
owens91's Avatar
well so far in this experiment i will say this,First I did this when the fuel gauge hit the red line, when i put exactly 1 gallon of 87 i got 15.4 miles before it ended up exactly back at the red line. Then i put 1 gallon of 93 from the same Hess gas station and got 20.7 miles before being back at the red line. Also i have noticed a bit more response at the pedal, so tomorrow when i get paid i will put 17 gallons (fill up) of 93...if i get more than 260-290 then i got my answer...will keep u guys posted !
Old Jul 31, 2013 | 04:25 PM
Way too many variables in your 1 gallon experiment, if you want to try it, go for it. I still say its a waste of your money if they don't require it.
Old Sep 19, 2013 | 10:23 PM
owens91's Avatar
update to this experiment... didnt get better MPG but i will say this at a stop light it did seem to get more kick off the line
Old Sep 20, 2013 | 08:03 AM
Then your car is probably knocking with the 87 and fuel is quenching the real issue. Could need plugs/wires/tune-up/sensor cleanings/ etc.
Feb 16, 2012 11:08 AM
jaws2008
Nov 14, 2008 08:21 PM
RocknSS04
Dec 1, 2007 07:18 PM
Greeny
Jul 17, 2006 08:11 PM
Scooze
Oct 13, 2005 12:14 AM
