Help me find the website that sells...
Old Feb 18, 2010 | 07:04 PM
Jomao_o's Avatar
Default Help me find the website that sells...
the u bend delete. I know about getting one from zzp but i recently spotted one in another site but i just cannot remember. all of your help is appreciated greatly. this spring i am definitely getting that if not both the cai and u bend delete, i wanted to compare prices of the other website but like i said i cant remember. if anyone knows where i can find it or another, just trying to compare and save if possible. unless zzp is the most inexpensive
c'mon uncle same gimme the monaay!
thnx guys
Old Feb 18, 2010 | 07:22 PM
Wilco's Avatar
Jose, the Non-Stainless Steel DP from ZZP (the 2.5/cat) runs $205. If you go SS then your cost goes up.
Old Feb 18, 2010 | 07:24 PM
If you go to any exhaust shop they can cut that piece out and weld in a straight pipe with o2 bung (roughly $40)
but you will want the whole downpipe, and ZZP is the cheapest and best there.
Old Feb 19, 2010 | 12:43 AM
Jomao_o's Avatar
Alright guys, thanks for the advice.
...see that was harmless. :P
Old Feb 19, 2010 | 01:04 AM
Wilco's Avatar
Oye jose, did you ever looked those tail light covers up? I'm painting mine the same as the car! That should look very nice, I hope!
Old Feb 19, 2010 | 11:00 AM
Jomao_o's Avatar
Si, i did. i posted on that thread, i found the gts for the rear.
oye wil, i went on zzp and its not as simple as i thought it would be, there are options and models, which one is the one for my car?
Old Feb 19, 2010 | 11:05 AM
since you're supercharged I would recommend
3" 304 Stainless Steel bolt-on with Cat + front and rear gaskets.
Also just shoot ZZP an email if you want and explain to them what you have and what you should do.
Old Feb 19, 2010 | 01:28 PM
Jomao_o's Avatar
This one here, i won't throw a code correct.
Perfect! thanks alot mike.
You've always had the right answer man, how do you do it? *in a dramatic on knees way* HOW DO YOU DO IT?!
In all seriousness i appreciate it, every member that has given me advice and their recommendations since joining here last year. when you guys told me i could do better than that modded ls and look now. thanks
Old Feb 19, 2010 | 01:29 PM
There's no guarantee that it won't throw the code. There actually is a good chance that it will. But that's how aftermarket cats work
But when you get the code, it's time for a ZZP PCM
Old Feb 19, 2010 | 01:59 PM
Wilco's Avatar
With a high flow cat there's a 95% chance that your car will throw the code. I'd recommend the 304 SS cause it will resist corrosion better. I got the 2.5" but since yours is S/C a 3" will probably work better. Is your exhaust after the cat 2.5" or 3"?
