> Car Stuff + Other Stuff <
Old Jul 10, 2012 | 05:45 AM
Question > Car Stuff + Other Stuff <
Hi Member's, just filling in some empty space & giving you something to check out after you've checked everything else out on the MCF Life sure is like a Roller Coaster with all it's up's & downs ~> Wish you more `up's then down's..EnJoy the Ride 4-Sure = Be the driver of your life & Monte Carlo(s)
<LI class=first sizset="164" sizcache="65">Extreme Campers for Off-Roading <~ Which one do you like ? or want to own ?<LI class=first sizset="164" sizcache="65"><LI sizset="165" sizcache="65">Audi R8 E-tron at the Nürburgring <~ Electric POWER<LI sizset="165" sizcache="65">
<LI sizset="149" sizcache="65">Black Boxes: Fact Versus Fiction What do the data recorders riding shotgun actually do?
<LI sizset="151" sizcache="65">Roller Coasters Versus Supercars We've matched 5 of the fastest rides with their automotive equivalents.
<LI sizset="153" sizcache="65">20 Ways To Save Gas This Summer Follow these tips to experience a little less pain at the pump.
<LI sizset="155" sizcache="65">Rack It Up Too much junk for your car’s trunk? Try a space-saving rack.
<LI sizset="157" sizcache="65">Concept Cars Can Predict the Future Here's what the most recent crop tells us.
<LI sizset="159" sizcache="65">Which 2012 Cars Have the Best Tech? Cars with tech that makes life easier and more entertaining on the road.
<LI sizset="161" sizcache="65">Is a 2000 Mph Car Actually Possible? A small workspace is trying to hit speeds beyond 2000 mph.
10 Handy Smartphone Apps for Drivers If you have an issue behind the wheel, there’s probably app for it.
Hottest New Motorcycles
The 10 coolest new bikes for the 2012 riding WoW, there's some nice new bikes out there...Which one do you like best ?
Old Jul 10, 2012 | 09:12 AM
Default How Car Engines Work
by Marshall Brain
MORE STUFF LIKE THIS:
Top 10 Improvements in Engine Design
<!-- dtl_id= //-->Image Gallery: Exotic Engines
The Corvette ZR1's supercharged 6.2-liter V8 engine produces 620 horsepower standard. See more pictures of car engines. See more pictures of engines.
Photo courtesy General Motors
Old Jul 10, 2012 | 09:14 AM
Default Continued from above
Up Next
­Have you ever opened the hood of your car and wondered what was going on in there? A car engine can look like a big confusing jumble of metal, tubes and wires to the uninitiated.
You might want to know what's going on simply out of curiosity. Or perhaps you are buying a new car, and you hear things like "3.0 liter V-6" and "dual overhead cams" and "tuned port fuel injection." What does all ­of that mean?
­­In this article, we'll discuss the basic idea behind an engine a­nd then go into detail about how all the pieces fit together, what can go wrong and how to increase performance.
­The purpose of a gasoline car engine is to convert gasoline into motion so that your car can move. Currently the easiest way to create motion from gasoline is to burn the gasoline inside an engine. Therefore, a car engine is an internal combustion engine -- combustion takes place internally.
Two things to note:
  • There are different kinds of internal combustion engines. Diesel engines are one form and gas turbine engines are another. See also the articles on HEMI engines, rotary engines and two-stroke engines. Each has its own advantages and disadvantages.
  • There is such a thing as an external combustion engine. A steam engine in old-fashioned trains and steam boats is the best example of an external combustion engine. The fuel (coal, wood, oil, whatever) in a steam engine burns outside the engine to create steam, and the steam creates motion inside the engine. Internal combustion is a lot more efficient (takes less fuel per mile) than external combustion, plus an internal combustion engine is a lot smaller than an equivalent external combustion engine. This explains why we don't see any cars from Ford and GM using steam engines.
Let's look at the internal combustion process in more detail in the next section.
Launch Video
Fast and Loud: Paint Demo
Old Jul 10, 2012 | 09:16 AM
Default Continued part 3
<TABLE width="100%" height="100%"><TBODY><TR><TD vAlign=middle>Producing More Engine Power
</TD></TR></TBODY></TABLE>
<IFRAME style="WIDTH: 1px; DISPLAY: none; HEIGHT: 1px" id=ob_iframe src="http://widgets.outbrain.com/nanoWidget/3rd/comScore/comScore.htm"></IFRAME>
<WBR><STYLE type=text/css> .voterDiv .ob_bctrl{display:none;} .ob_pdesc IMG{border:none;} .AR_1 .ob_what{text-align:right;clear:both;} .AR_1 .ob_clear{clear:both;} .AR_1 .ob_container{width:100%;position:relative;overflo w:hidden;} .AR_1 .strip-img{width:109px;height:109px;border:none !important;margin:0px !important;display:block;padding:0px !important;background-image: url(http://widgets.outbrain.com/strip_default.png)} .AR_1 .item-link-container{text-decoration:none;} .AR_1 .strip-rec-link-title{font-size:13px;font-weight:normal;line-height:16px;} .AR_1 .strip-rec-link-source{font-size:12px;line-height:16px} .AR_1 .strip-like{padding-bottom:4px;font-size:14px;line-height:16px;height:20px;font-weight:bold;} .AR_1 .item-container a,.AR_1 .item-container a:hover,.AR_1 .item-container a:visited{border:medium none;text-decoration:none;} .AR_1 .ob_video{border:medium none;position:absolute;top:5px;left:5px} .AR_1 .ob-rec-link-img{position:relative;} .AR_1 .wbr:before {content: \"\200B\"} .AR_1 .ob_container_recs{width:100%;position:absolute;} .AR_1 .ob_container_recs A{display:inline;direction:ltr;text-align:left;} .AR_1 .ob-text-content A{width:100%;padding:0px 0px;} .AR_1 .ob-text-content{padding-top:6px;} .AR_1 .item-container A.ob-text-content{display:block;} .AR_1 .ob_container_recs .item-container{float:left;direction:ltr;width:111px;mar gin-bottom:300px;padding-right:9px;} .AR_1 .ob_container_recs .ob-last{padding-right:0px;} .AR_1 .ob_container_shadow_outer{position:static;width:1 00%;} .AR_1 .ob_container_shadow .item-container-shadow{position:static;overflow-x:hidden;width:0px;float:left;direction:ltr;} .AR_1 .ob_container_shadow .item-container{width:111px;visibility:hidden;float:left } .AR_1 .item-container-ad .paid-distribution{border-color:#FFF;border-style:solid;border-width:2px 2px 0 0;color:#FFF;float:left;direction:ltr;font-family:verdana,arial,sans-serif;font-size:9px;font-size-adjust:none;font-stretch:normal;font-style:normal;font-variant:normal;font-weight:normal;line-height:normal;padding:2px 4px; position:relative; top:-18px; z-index:10;clear:both;} .AR_1 .item-container-ad .ob-text-content{position: relative;top:-19px;clear:both} </STYLE>More From How Stuff Works
How Camshafts Work
(HowStuffWorks "Auto")
How Diesel Engines Work
Understanding: Car Engine Basics
(HowStuffWorks Videos)
How Quasiturbine Engines Work
(HowStuffWorks )
Why am I not allowed to use my cell phone in airplanes or hospitals?
(HowStuffWorks )
Old Jul 10, 2012 | 09:17 AM
Thumbs up Part 4 & last (4 now)
<WBR><STYLE type=text/css> .voterDiv .ob_bctrl{display:none;} .ob_pdesc IMG{border:none;} .AR_2 .ob_what{text-align:right;clear:both;} .AR_2 .ob_clear{clear:both;} .AR_2 .ob_container{width:100%;position:relative;overflo w:hidden;} .AR_2 .strip-img{width:109px;height:109px;border:none !important;margin:0px !important;display:block;padding:0px !important;background-image: url(http://widgets.outbrain.com/strip_default.png)} .AR_2 .item-link-container{text-decoration:none;} .AR_2 .strip-rec-link-title{font-size:13px;font-weight:normal;line-height:16px;} .AR_2 .strip-rec-link-source{font-size:12px;line-height:16px} .AR_2 .strip-like{padding-bottom:4px;font-size:14px;line-height:16px;height:20px;font-weight:bold;} .AR_2 .item-container a,.AR_2 .item-container a:hover,.AR_2 .item-container a:visited{border:medium none;text-decoration:none;} .AR_2 .ob_video{border:medium none;position:absolute;top:5px;left:5px} .AR_2 .ob-rec-link-img{position:relative;} .AR_2 .wbr:before {content: \"\200B\"} .AR_2 .ob_container_recs{width:100%;position:absolute;} .AR_2 .ob_container_recs A{display:inline;direction:ltr;text-align:left;} .AR_2 .ob-text-content A{width:100%;padding:0px 0px;} .AR_2 .ob-text-content{padding-top:6px;} .AR_2 .item-container A.ob-text-content{display:block;} .AR_2 .ob_container_recs .item-container{float:left;direction:ltr;width:111px;mar gin-bottom:300px;padding-right:9px;} .AR_2 .ob_container_recs .ob-last{padding-right:0px;} .AR_2 .ob_container_shadow_outer{position:static;width:1 00%;} .AR_2 .ob_container_shadow .item-container-shadow{position:static;overflow-x:hidden;width:0px;float:left;direction:ltr;} .AR_2 .ob_container_shadow .item-container{width:111px;visibility:hidden;float:left } .AR_2 .item-container-ad .paid-distribution{border-color:#FFF;border-style:solid;border-width:2px 2px 0 0;color:#FFF;float:left;direction:ltr;font-family:verdana,arial,sans-serif;font-size:9px;font-size-adjust:none;font-stretch:normal;font-style:normal;font-variant:normal;font-weight:normal;line-height:normal;padding:2px 4px; position:relative; top:-18px; z-index:10;clear:both;} .AR_2 .item-container-ad .ob-text-content{position: relative;top:-19px;clear:both} </STYLE>You Might Also Like
Inside Engines
(this site)
How HEMI Engines Work
Sponsored
Create Your Own Smartphone App With Infinite Monkeys – No Coding Knowledge Required
(MakeUseOf.com)
Sponsored
Meet The Future of Harley-Davidson
(Fox Business)
Inside Engines
(this site)
More Great Links
Top 10 Green Driving Tips
5 Scariest Stunt Car Feats
The Ultimate CarStuff Fan Quiz
5 Warning Signs You Need New Tires
10 Most Expensive Classic Cars
Watch American Chopper videos >>
You Might Also Like
Chevy 454-cid V-8 EngineChevy engineers had to bend some of their rules to get as much power out of the Chevy 454-cid V-8. America's "fuel shock" would ultimately sentence big-inch high-performance cars to oblivion. Learn about one of Chevy's milestone performance engines.
How does the intake manifold affect your engine?Your engine needs just three things to run: air, fuel and spark. That said, it's easy to see why the intake manifold -- the component your engine breathes through -- is so important.
Popular Articles
Old Jul 10, 2012 | 09:39 AM
Blazed SS's Avatar
IT HERTZ
Wow Kid Space Lots on info on this Super Thread !!! Thanks man !!!
Old Jul 10, 2012 | 09:41 AM
Great to see you online & thanks for your words. How's the training going..(Post a update in our `Blog).
Great that you found the infor Super...I just do my best to fill in all the empty spaces on the MCF & give our member's something to read & enjoy...Wish you a Super Day out there on the West-Coast of the U.S.A.
Peace/Out from `Space
Old Jul 10, 2012 | 10:39 AM
There was a show on discovery channel about Extreme RV's
There were some pretty killer and Bazarre Units for sure....
It was very interesting to say the least...
Old Jul 11, 2012 | 06:17 AM
Next » <~
1 of 30 images
You might remember the 1967 Pontiac GTO as the spy car from the action movie XXX. The 1967 Pontiac GTO is one of the most imposing muscle cars ever built. What classic muscle car did Joe Dirt refer to as a "Hemi"? Find out on the next page.
MY86MONTESS
Aug 23, 2015 07:38 PM
Aug 15, 2012 06:53 PM
88montessman
Feb 26, 2009 06:37 AM
rj
Mar 29, 2008 01:53 AM
gonsailin
Dec 3, 2007 03:40 PM
