>Auto Repair For Dummies<(?)
Old Feb 22, 2016 | 09:26 AM
Thumbs up >Auto Repair For Dummies<(?)
Hi Member's, I was searching for a
site to help me with Auto Repairs
and found the below
I always share with my `friends
Some of my friends help me with the
big words
From Auto Repair For Dummies, 2nd Edition by Deanna Sclar
Following some basic auto repair safety rules and a monthly maintenance schedule will keep you safe and prevent auto problems later. Disassembling auto parts and putting them back together is easier if you stay calm and avoid distractions.
Auto Repair Safety Rules
When you’re repairing your car or doing basic maintenance, practice these safety methods to avoid injury to yourself and damage to your automobile and to be prepared in case of a mishap:
  • Don’t smoke while you’re working on your vehicle.
  • Never work on your vehicle unless the parking brake is on, the gearshift is in Park or Neutral, and the engine is shut off (unless it has to be running for you to do the work).
  • Be sure that the parts of the engine you’re working on are cold so that you don’t get burned.
  • Never jack up a car unless the wheels are properly blocked.
  • Use insulated tools for electrical work.
  • Before using a wrench or ratchet on a part that seems to be stuck, make sure that if it suddenly comes loose, your hand won’t hit anything. To avoid the possibility of bruised knuckles, pull on wrenches rather than push them whenever possible.
  • Before working on your car, take off your rings, tie, long necklaces, and other jewelry, and tie back long hair.
  • If you’re using toxic chemicals such as coolant, cleaners, and the like, keep them away from your mouth and eyes, wash your hands thoroughly after using them, and either store them safely away from pets and children or dispose of them in a way that’s safe for the environment.
  • Know that gasoline is extremely dangerous to have around. Not only is it toxic and flammable, but the vapor in an empty can is explosive enough to take out a city block.
  • Work in a well-ventilated area. If possible, work outdoors in your driveway, your backyard, or a parking lot. If you must work in your garage, be sure to keep the garage door open and the vehicle as close to the door as possible.
  • Keep fire extinguishers handy. Place one in your garage and one under the front seat of your vehicle. (Be sure to secure it with a bracket that will prevent it from rolling under the pedals.)
Monthly Auto Maintenance Checklist
Taking the time for regular under-the-hood vehicle checks will help prevent problems later. Spending 15 minutes every month for an under-the-hood check may prevent 70% of problems that lead to highway breakdowns. Convinced? Then run through the following list once a month or every 1,000 miles:
Check the air filter.Check the automatic transmission fluid level on the dipstick.Check the accessory belts.Check the brake fluid.Check the battery.Check the power-steering fluid.Check the coolant.Check the windshield wipers and amount of windshield washer fluid.Check the hoses.Check the wiring.Check the oil level on the dipstick.Check the tires.
Tips for Easily Disassembling and Reassembling Auto Parts
The first rule of auto repair jobs is never hurry! If things get rough, take a break. You may get a whole new perspective when you go back to work. Keep distractions to a minimum, don’t answer the phone, keep the kids and the dog away, and relax. Don’t panic if you hit a snag — sit quietly and think about it. If the parts fit together before, they’ll fit together again.
The following steps outline a process for disassembling and reassembling complex auto parts — or anything, for that matter:
  1. Get a clean, lint-free rag and lay it down on a flat surface, near enough to reach without having to get up or walk to it.
    After you remove each part, you'll lay it on the rag, which shouldn’t be in an area where oil or dust or anything else can fall on it and foul the parts.
    If you’re going to use something that blasts air for cleaning purposes, leave enough of the rag uncluttered to flip it over the parts resting on it.
  2. Before you remove each part, ask yourself the following questions:
    • What is this thing?
    • What does it do?
    • How does it do it?
    • Why is it made the way it is?
    • How tightly is it screwed on (or fastened down)?
  3. As you remove each part, lay it on the rag in clockwise order, with each part pointing in the direction it lay in when it was in place.
    When you’re ready to reassemble things, the placement and direction of each part tells you when to put it back and how it went.
  4. If you’re making notes, assign each part a number indicating the order in which you removed it — part #1, part #2, and so on.
    You can even put numbers on the parts with masking tape if you’re afraid that the rag may be moved accidentally.
  5. When you’re ready to reassemble everything, begin with the last part you removed, and then proceed counterclockwise through the parts.
Old Feb 22, 2016 | 09:30 AM
Talking More to see & Read...WoW, We Get Smart ? LOL
Training Material to Learn Auto Repair from YouFixCars.com
www.youfixcars.com/learn-auto-repair.html
Learn auto repair with a Master Technicians proven resources. Perfect for the do it yourself car mechanic or automotive student in training.
Why YouTube Is the Best Place to Learn How to Fix Cars ...
www.caranddriver.com › Features
Car and Driver
In pitching this purchase to my wife, I actually argued that owning such a thing would teach me valuable skills in the field of automotive repair. Of course, I ...
Learn To Diagnose And Fix Your Own Car With These 10 ...
www.makeuseof.com/.../learn-to-diagnose-and-fix-your-own-car-with-th...
Jun 22, 2012 - RepairPal is a comprehensive encyclopedia for auto repair and maintenance information for consumers. You have auto care advice, repair ...
Old Feb 22, 2016 | 11:31 AM
Talking "A penny saved, is a penny earned ?" I've lost all mine ?
Click above>Warning> Maybe X rated
I don't have any cent$ (4-$ure)
can someone send me a
Penny
I'm still waiting for my Penny
Old Feb 23, 2016 | 09:09 AM
Question The right tools to do the job ?
Member's do you have all the tools you need to do
basic work on your Monte Carlo ?
What do you have ?
The Top 14 Tools for a Beginner Mechanic | Enduring ...
www.enduringautomotive.com/top-14-tools/
Jun 24, 2012 - Today, I can perform most automotive repairs with the tools I've accumulated over the past decade. Here's a list of must haves for the beginning ...
