* How to Prevent Foggy Headlights *
Old May 18, 2012 | 06:50 AM
Thumbs up * How to Prevent Foggy Headlights *
How to Prevent Foggy Headlights ?
Are your headlights are always collecting water inside? Here are a few valuable tips to prevent the fog for good.
<!-- /contentHeader.tmpl --><!-- byLine.tmpl -->By Mike Allen of Popular Mechanic's (Borrowed & posted by a SpaceAlien)
Condensation is normal, at least in small doses. Car manufacturers say that condensation may cover 50 percent of the surface of the lens before it's considered a problem.
<!-- shortPagination.tmpl --><!-- /shortPagination.tmpl -->
<!-- article -->Let's examine why there is water inside the lamp assemblies in the first place. As the outside temperature goes down and your nice warm headlamps cool off (either from being in the sun or just from being turned on), cooler, moister outside air trickles into the housings. The housings are vented top and bottom to allow for pressure differences, or they would quickly crack and fail. When the clear plastic lens is even a little bit cooler than the air inside the housing, droplets of moisture will condense on the inside of the lens. That’s normal. When the outside temperatures come back up in the morning, the moisture will evaporate.
Some vehicles don’t vent as well as others. Some drivers keep their cars parked in shady, damp areas or in cool, damp underground parking structures. And the moisture collects not as tiny droplets of mist but as what looks more like raindrops, and can even run down the glass and pool inside the housing.
Check to see if there’s a Technical Service Bulletin for your make and ­model of vehicle. If so, there may be a retrofit housing or an upgrade to the venting system. If not, you’re on your own. The first thing to try, if all you have is droplets, is to leave your headlights on while driving for a couple of hours, forcing the moisture off. If you have a spoonful or more splashing around, you may need to remove the housing and dry it out. Pour off the excess water, then add a few ounces of rubbing alcohol to the housing, sloshing it around and pouring it out. Repeat. Let the housing dry for a couple of hours in the sun or inside a nice warm house, preferably in some air that’s moving. Check that any vents aren’t plugged with spider eggs or mud. Install the housing and try to park facing south.
(Illustration by Dogo)
Old May 18, 2012 | 08:10 AM
Longislandmonte
May 28, 2015 06:35 AM
16With01MonteSS
May 14, 2013 11:27 AM
djtiny
Feb 29, 2012 05:18 PM
Budsjlm
May 23, 2011 08:30 AM
SamanthaF
Sep 12, 2010 11:12 PM
