need help monte carlo ss 2000
Old Nov 17, 2011 | 10:01 PM
MONTE CARLOS -SS- 2000 FULL's Avatar
Thumbs up need help monte carlo ss 2000
hey no to good in englis sorry hope somebody speak french a little bonjour jespere ici trouver de laide pour ma voiture jais un probleme avec mon toit ouvrant il fait tic tic tic est il nouvre pas le moteur du toit fonctionne mais on dirais que lengrennage a des probleme donc si quelquun peut me donner des conseils cela seras tres apprecier jabite montreal est je sait me debrouiller pas mal avec des directive mercie a tous et sourtout au pros de la monte carlos qui sont ici bonne soiree a tous hope help good morning has all although is a way to make me understand by my new friends englophonne well fact a purchase of the monte carlo month ago all seem me in very good order except two small problem there is my roof and also the sensor of the catalizeur of the car to be change so if there is a person who might have some small tips to facilitate the work this would be pretty cool and then to my sunroof I must absolutely take-uot the roof inside of the car to get the engine of the roof Yes or not is there an easy way to repair the engine works when I push the button to front it make three click on and the engine seems to move as if lengrenage had a problem would it be possible that roof stuck glue by heat or there - it way to open manually thank-you
Old Nov 17, 2011 | 10:08 PM
Franks 03SS's Avatar
2011 Monte Of The Year
Hey bienvenue à la montecarloforum! J'espère que quelqu'un ici peut vous aider, je doute que quiconque parle français sur ce forum, mais on ne sait jamais. J'utilise un autre logiciel de traducteur sur mon portable,
Old Nov 17, 2011 | 10:28 PM
Wow Frank u speak French??
Welcome to the Forum
Old Nov 17, 2011 | 10:40 PM
Welcome to the site.
Old Nov 18, 2011 | 01:53 AM
mousehousemoparman's Avatar
Welcome to the forum. Lost my French at least a generation ago. I used to live near you in Burlington Vermont.
Old Nov 18, 2011 | 06:04 AM
DRuben's Avatar
He has a problem with his sunroof making a tic tic tic sound and he is sure its not his engine. The sunroof does work though. If someone would give him advice he will appreciate it and thanks to all the pros of the Monte Carlo that are here, have a good evening everyone.
I know what you said Frank lol (tricheur) :p
Old Nov 18, 2011 | 06:23 AM
Old Nov 18, 2011 | 09:23 PM
d-666's Avatar
Salut je parle le français, je suis du Québec..pour ton toit, démonte le headliner et va voir l'engrenage/mécanisme pour vérifier que tout est correct..
Bienvenue sur le forum
yeah guys i speak french,don't you know that frogs speak french?lolll
Old Nov 18, 2011 | 09:31 PM
Crusader SS's Avatar
Bien Veneau... Unfortunately my french is a little rusty... I had the exact same problem... Fix, was to clean out the tracks completely, that means all grease removed... Then I applied a silicone based white grease (can't remember the name) and voila, the tic, tic, tic was gone and this was done 1 year ago with opening the sunroof everyday... Bon soire...Cheers,
Old Nov 18, 2011 | 11:40 PM
Je suis heureux de ne pas le seul qui parle français!
