I have a gas smell on the dipstick when I check it
Old Feb 14, 2016 | 06:16 PM
spirit1290's Avatar
Default I have a gas smell on the dipstick when I check it
About a month ago I bought a 1995 monte carlo with a 3.4 dohc. Although I'm a single female I do know enough about cars to check things before buying a car. Everything seemed fine until a week after I bought it. Now the valve cover gaskets have to be replaced. I haven't been able to get it fixed yet so I only drive it when I have to. I do check the oil every time and now when I pull the dipstick out it smells like gas. If I drive it more than a few miles it starts acting like its going to quit running for a minute and then it'll be fine for a while. I don't want to spend a lot of money to replace the gasketsif this ends up being a manor problem
Old Feb 14, 2016 | 07:04 PM
Default Thanks Mr Google
Check the below (Hope it helps You)
When Engine Oil Dip Stick Smells Of Petrol. - Car Talk ...
www.nairaland.com/1491851/when-engine-oil-dip-stick
Oct 25, 2013 - 31 posts - ‎12 authors
when you pull out engine oil dip stick and the faint smell of fuel hits your ..... I just changed my plugs to brand new NGKs that I ordered from ...
oil has gas smell - Car Talk
community.cartalk.com/discussion/2290424/oil-has-gas-smell
Feb 18, 2013 - It leaks a little oil and when i recently checked it (level was good), ... If you smell gasoline on the dipstick it might be advisable to drain and refill ...
Dip stick/oil smells like gasoline.... - Ford Mustang Forum
www.allfordmustangs.com › ... › 2011 - 2014 Mustang GT Tech
Nov 29, 2012 - So I was checking my oil the other day and I noticed the dipstick smellslike gas. It's gas for sure. You can smell it. It's pretty strong too. Smells ...
Oil on dipstick smells a little like Gasoline | Passenger Car ...
www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat...
Dec 10, 2012 - 15 posts
Mazda 0w20 smells really strongly of fuel anyways. At least according to my tech, itsmells like really clean oil ( which i guess to my nose smells ...Oil Smells Like Gas - Fuel Dilution?
Nov 12, 2013
Oil smells like Gas | Mechanical /Maintenance Forum ...
Jul 9, 2010
More results from www.bobistheoilguy.com
why would oil dipstick smell like gass? - Nissan Forum | Nissan Forums
forums.nicoclub.com/why-would-oil-dipstick-smell-like-gass-t235950.ht...
Mar 17, 2007 - how badly does the oil smell like gas, and is there a large amount of fuel... since I put my SR in, and the oil has always smelled a little like gas, ...
Oil dipstick smells of gas - Bimmerforums
www.bimmerforums.com/.../showthread.php?...Oil-dipstick-smells-of-ga...
Aug 1, 2012 - Join Date: Aug 2011; Location: Ontario, Canada; Posts: 243; My Cars: 1980 E21 ... Oil does smell a bit like gas, could just be your imagination.
If your oil dipstick smells like gas... - RX8Club.com
www.rx8club.com › General Topics › RX-8 Discussion
Feb 22, 2004 - The oil in my piston engine smells like gas. Most of the problems being mentioned about the rotary happen in piston engine too am I wrong?
Smell of gasoline in engine oil? - North American Motoring
www.northamericanmotoring.com/.../156065-smell-of-gasoline-in-engin...
Oct 13, 2008 - Yesterday, I took out the oil dip stick to check my engine oil. ... I would beleive if the oil smells like gas then there is gas in it which will break ...
Smell of petrol in the oil HELP! - Servicing - Automotive - Whirlpool
forums.whirlpool.net.au › Automotive › Servicing
Whirlpool
Jan 8, 2014 - Hi there, I was recently checking the oil on my niece's car as I do the basic servicing of the ... Engine oil will smell like fuel at some point. ... rainbow colouring on the oil ?? take out dipstick and walk out into the bright sun and ...
Gasoline smell on dipstick? - Supraforums.com
www.supraforums.com › ... › MKIV (1993-1998)
On my 94TT, stock, with 55K miles I have noticed a gasoline smell when I check my oilon the dip stick. My car seems to be in great running condition and I have ...
Searches related to gas smell on my oil dipstick
