electrical question
Old Sep 29, 2017 | 05:41 AM
bullett's Avatar
Question electrical question
Hey fellas! So I am restoring a 1978 Monte Carlo that lets just way was pretty hacked up electrically. I have a bit of experience with electrical, and think that I got it wired all correctly and looking good, but would like to test in. Problem is its a rolling chassis, with no motor, trans, or interior at the moment, but I do have all the wiring in place. Interior and exterior. Can I hook up a 12V car battery, positive to the wires that run from the fuse box to the starter solenoid and black to a ground and do some testing without frying anything or would this be too much power and cause damage? Its a first for me, usually the vehicles I have done previously have had the engine and everything hooked up. Thanks for any input!!!!
Old Sep 29, 2017 | 10:03 AM
Smile
I HAVE NO IDEA IF THIS WILL WORK ON NOT?
However the thing you may want to try and this worked on an electrical seat in the junk yard. Take a 9volt battery like is in Fire alarms and hook it up.
It actually move the seat enough to be able to get it out.
Another would be use a Jumper pack.
As long as you have fuses they will usually blow if you have something wired wrong.
Hope that helps a bit.
You may also want to check youtube to see if there is something there?
