Dash lights, temp. control lights, radio lights
Hello,
I have a 2003 M.C. SS. My message board flashed service engine soon. So I ran the code. It came back as Low Fuel Pressure. Changed fuel filter, and pressure regulator. It is still coming up as Low fuel pressure. The car runs great. No hesitations on acceleration. No hard starts. Now the dash lights, radio lights, and the temp. control lights come on when I first turn the key. After I start the car about two seconds later they dim out, and fast. Do I have a ground problem,or is it a relay problem? Could I be way off base? Everyone I talk to does not believe me, until they see it for themselves. Can anyone help me? Thank you, Roger |
Seeing how no one has responed. I bought a new fuel pump, and a headlight w/dimmer switch. I hope this works. If not, anyone want to buy a 2003 Monte SS with less than 75K? Kidding it is not for sale, but it does have less than 75K.
Headlights and dimmer switch.
Found out that when I replaced the the headlight and dimmer switch kit. All is well with the dash lights, and the message board. No messages from control center. So if anyone needs to fix a lighting issue, check the headlight/dimmer switch kit. It could be the answer to the problems.
2003 monte carlo ss
i have a 2003 mc ss and the dash lights sometime work sometime not any ideas
I have a 2003 M.C. SS. My message board flashed service engine soon. So I ran the code. It came back as Low Fuel Pressure. Changed fuel filter, and pressure regulator. It is still coming up as Low fuel pressure. The car runs great. No hesitations on acceleration. No hard starts. Now the dash lights, radio lights, and the temp. control lights come on when I first turn the key. After I start the car about two seconds later they dim out, and fast. Do I have a ground problem,or is it a relay problem? Could I be way off base? Everyone I talk to does not believe me, until they see it for themselves. Can anyone help me? Thank you, Roger[/QUOTE] |
I changed my ambient light sensor, and it took take of a lot of my problems. My lights no longer dim, and my service vehicle soon light is off. All because of a little sensor on the dash. On to the next.............
I have the same problem with my 03 Monte. I have not been able to get to the bottom .
Originally Posted by rg9johns
(Post 564897)
The background lights is most likely going to be a bad headlight switch. The ac not working intermittently is one that I’m still working on.
Can the bcm be tested?
Originally Posted by Jvillemorgan
(Post 727825)
Originally Posted by Mike Palatka
(Post 723638)
l have the same problem and have not been able to get to fix or figure out what is causing the problem. My AC will just shut off, my background lights, radio, window locks, steering wheel controls all don’t work intermittently. I hope you have better luck with this issue than I have had.
