Check engine light problem
Old Feb 12, 2017 | 01:27 PM
Jwayne's Avatar
Default Check engine light problem
I have a 2001 Monte Carlo and the check engine light is on. It was read by Autozone and they said its a PO440. I replaced the Purge Valve and its still on. This all happened after i went to emissions testing and it said 3 need readiness a day after. Do i have to change the Vent Valve also
Old Feb 12, 2017 | 07:53 PM
plumbob's Avatar
P0440 is a tricky one. The vent valve is the most common culprit. It's in the driver's rear wheel well. If you remove it you should be able to freely blow through the hose with little resistance. If not, it's clogged and needs to be replaced. Could also be a bad fuel tank pressure sensor. And if you're having trouble filling the tank (pump nozzle keeps shutting off) it's the charcoal EVAP canister.
Please keep us posted.
Old Feb 13, 2017 | 01:04 PM
Jwayne's Avatar
Thanks... the check engine went off.. Now im just tryn to get the readiness to kick in i drove 150 miles so im hoping one more week will make the car kick in
Old Feb 13, 2017 | 04:54 PM
plumbob's Avatar
I believe it only takes 50 miles to become ready after clearing codes, but I could be wrong.
Old Feb 13, 2017 | 04:56 PM
3 driving cycles I believe.
Old Feb 13, 2017 | 05:54 PM
WBody's Avatar
X2 cycles. I bought a car scanner that has the ability to check to see where the systems are. Might be a good idea to buy something like that if you plan on working on your vehicle a lot.
