Check engine light on
Old Sep 2, 2015 | 02:57 PM
Martin2467's Avatar
Default Check engine light on
Hey everyone I have a 2006 Monte Carlo ss 5.3l v8 and I replaced my alternator and it all runs fine, but my check engine lights on now which wasn't on before, does anyone have any ideas?
Old Sep 3, 2015 | 02:36 PM
softwarejanitor's Avatar
Get an OBD-II code reader (around $50 from places like Harbor Freight) and read the codes from the ECM and it should tell you what the error was (make note of the code # so you can look it up online). Chances are it was just something that got set errantly when you had the battery, etc, disconnected to change the alternator. If that is the case you can use the code reader to clear the codes and then drive the car around 20-30 miles and if the light doesn't come back on again you are good to go. If it does, then hook up your code reader again and go from there.
Places like Auto Zone will read the codes for you for free (many shops chare a fee just to read the codes -- often as much or more as buying the tool to do it yourself)... but it is much handier to have your own code reading tool.
Old Sep 3, 2015 | 07:12 PM
RickCoMatic's Avatar
If there is an AutoZone Store near you, ... you can stop-in and use their Code Reader for free.
Just as soon as you get the Code that tripped the light, ... the mystery's over.
Old Sep 3, 2015 | 07:58 PM
butch049's Avatar
Or go to Oreillys auto parts will read code for free and shut light off and tell you what code means might be nothing.
