Wipers
Old Aug 16, 2016 | 08:41 PM
Dj_bosse's Avatar
Default Wipers
I have a 2000 Monte Carlo and just replaced the turn signal switch but now my wipers don't work. When I turn the wipers on they'll come on once but not again until it's on high. The turn signals and high beams work fine and the wipers worked fine on the old switch. Any ideas?
Old Aug 16, 2016 | 10:01 PM
plumbob's Avatar
Did you use an aftermarket switch? They are known for problems like this. I know the AC Delco ones are pricey, but it seems they are the only reliable electrical part available for our cars.
Here's the cheapest AC Delco I could find: http://www.ebay.com/itm/NEW-ACDelco-...1W5za5&vxp=mtr
Also make sure it's identical to the old switch. I once replaced the multi-function switch on a '85 Celebrity I had with one from the dealer and had a similar problem. Checked the wiring and found two wires of about 12 were different, otherwise identical in every other way. Dealer parts guy didn't want to take it back even though it was his fault. Had to get the manager who agreed with me and made the exchange for the correct one.
BTW...When I did a search for 2000 Monte Carlo SS Multi-Function switch on Google is pulled up the wrong switch (P/N- D2545C) for an Impala. Had to go to the AC Delco site to get the correct part#(D6252C).
Old Aug 16, 2016 | 10:03 PM
Dj_bosse's Avatar
Pretty sure they were identical. It was s duralast. I guess I'll pull it out again tomorrow and update. Actually had bought one online and it didn't fit so had to buy one from autozone for $200
