window track problem
My son has a '96 Monte and both window tracks/guides/moldings need to be replaced. The steel inside the rubber of the track has rusted away causing the track to become flexible inside the door and the windows will fall out of the guide if they are put down. Called the local dealer and they want $285 per side just for the molding and since we're in Michigan going to the JY is no solution since 99.9% of the Montes there have the same issue.
Does anyone know of an aftermarket vendor for these parts? I'm having no luck finding anything online or it could be that I'm just looking in the wrong places.
