window came off track!!!
Old Oct 22, 2007 | 01:14 AM
ltrain925's Avatar
Default window came off track!!!
so my 98 z34 monte carlos driver side window rolls up, but when it gets to the top it gets pushed outside the molding and is off its track, i have to force it into place! i took off the door panel and i coudlnt' get to the window is there anything else i can do or is it just worth taking it in to get it fixed?
Old Oct 25, 2007 | 09:33 AM
06MCLTZ's Avatar
Default RE: window came off track!!!
I'll ask my buddy in a couple hours for you, he is an auto glass man, just give me sometime.
Old Oct 25, 2007 | 06:02 PM
scc24540's Avatar
my 97 has the same exact problem, what has happened is that the metal track has plastic inserts that slide inside the track to make the window operate properly, the one on the front side has worn out i dont know if you can replace that 1 thing but a after market track is only 100 bucks and is simple to replace. my vote is to replace it all and dont bother with the hassle of trying to make what you have work
Old Jan 24, 2008 | 12:19 PM
skeety's Avatar
for anyone in the future who runs into this thread...I did a little DIY that might help.
(granted, it's for a 2004 Monte...but hopefully the concepts are the same)
https://montecarloforum.com/m_74316/tm.htm
Old Mar 7, 2010 | 06:30 PM
Zmonte34's Avatar
my 96 did the same thing on both sides, but the spot welds had broken so i just welded them bak up and no problems since
Old Jul 21, 2010 | 12:37 PM
7498MonteCarlo's Avatar
Photobucket
Monte Of The Month -- August 2010
On my 98 LS, when I would roll up the window, when it almost got the top, the front of the window fell forward, and had a VERY hard time getting to the top (stayed in track though). Took off the door panel...nothing was wrong, just a worn out track. So, I re greased all window tracks, both sides, and they go up and down perfectly. The driver's side still falls a little, but pick up and keeps going. So, a tip...if your windows roll up and down slowly, just grease the hell out of the tracks...you'll see a difference!
Old Sep 21, 2010 | 09:12 PM
metallicblueice's Avatar
yeah my window did it too, i seen the kits for only $100, so it would be a good investment. it was a real pain when i took the door panel off and had to put the window up since the motor burnt up trying to roll up all the time.
Old Oct 23, 2010 | 09:40 PM
Squeegee's Avatar
i had the same problem. while the regulator is a simple job, the rivets are a pain in the ***, i broke the drill bit trying to get them out
Old Oct 20, 2011 | 04:25 PM
BlownUptoHigh's Avatar
my window hasnt come off track but it seem like its wobbly-ling back and forth, its really obvious when you roll it down about half way and get up to like 50mph, should i be looking at replacing the tracks?
Old Oct 21, 2011 | 08:33 AM
Please try not to bring back such OLD threads.
Also there's a good chance that a simple bolt has fallen out, or has come loose. I had to take my door panels off and retighten the bolts a few times.
Chris s
Jan 27, 2013 04:30 PM
DRuben
Apr 22, 2012 04:47 PM
kennyjohn
Jun 15, 2009 04:10 PM
ltrain925
Oct 22, 2007 01:26 AM
VinceF99
Sep 22, 2007 11:37 AM
