Whine noise on acceleration, check engine light
Old Apr 29, 2009 | 06:16 AM
saigashooter's Avatar
Kweef, that is exactly what the whine sounds like - too bad I don't actually have a turbo.
As for exhaust, no it is still stock.
It frustrates me that the codes are so vague, when the printers at work can tell you exactly where the paper got jammed and how to fix it.
Old Apr 29, 2009 | 07:38 AM
jaws2008's Avatar
GOT SPL
mine makes a similar noise. does it sound like it comes from the gauges area. one time i decided to fly around a corner and forgot to turn off the traction control and after that it make a noise like yours, it was that the traction control was still activated(no light on dash at the time thought). to fix it i hit the gas real hard to make the traction control come on. it fixed it.
see if it might be that. i still have other similar noises off and on sometimes though, mine are very inconstant.
Old Apr 29, 2009 | 08:17 AM
No, I can only hear it with the windows down, it is coming from under the car in the front.
And I've already got a new dash cluster, lol
Old Apr 29, 2009 | 01:26 PM
04 Intimidator's Avatar
Originally Posted by saigashooter
So I have an update, I am unable to get a decent video of the noise, but did get the code read for the CEL, it is a Large Emissions Leak. What would cause this, and is it the kind of thing that I could possibly fix?
What is the specific P-code for the error so I can look it up.
Old Apr 29, 2009 | 04:50 PM
P0455
Old Apr 29, 2009 | 07:19 PM
Well the P0455 is typically a loose gas cap. Take it off, put it back on and have Autozone clear the code for you.
As for the whining, there are a ton of TSB's on it. Just google your car for TSB's.
Old Apr 30, 2009 | 07:16 AM
I think I will simply replace the gas cap, as it has had issues sealing before. but never resulted in a code.
Old May 13, 2009 | 06:59 PM
snakeoil's Avatar
From your description, I'm pretty certain that this TSB covers your problem.
Some owners may comment on a whistle type noise on light acceleration.
Cause
Casting porosity in the throttle body may be creating the whistle noise.
Correction
Replace the throttle body and, if necessary, throttle body gasket. Refer to the Engine Controls sub-section of Engines in the appropriate Service Manual. The throttle body gasket should be inspected and re-used if not damaged.
I've had the problem for years ('02 LS). Chevy kept on telling me they had no idea what I was talking about. I was so mad when I read the TSB 04 b/c by that point the car was out of warranty.
Old Oct 19, 2009 | 04:25 PM
BRESRYA's Avatar
Default Whine noise
I keep hearing a whinning noise i have a 2002 monte carlo ss, and i hear it when i am accelerating, but not when i take my foot off. Anyone has any suggestion? Or answers..please help
Old Oct 19, 2009 | 06:58 PM
OVER_REMEDY's Avatar
supercharger?
