Where is Bank 1 Sensor 2?
Old Sep 14, 2007 | 02:36 PM
michael2938's Avatar
Default Where is Bank 1 Sensor 2?
After checking the engine codes, I found I need to replace the Bank 1 Sensor 2 O2 sensor. Can someone explain to me precisely where this is?
I have a 2001 SS. I am confused as to where this is, so if someone could explain it to me using physical location on the car such as (front or rear, passenger or drivers side, etc.). I'd appreciate it.
Thanks,
Mike
Old Sep 14, 2007 | 05:40 PM
TrickRacin's Avatar
Default RE: Where is Bank 1 Sensor 2?
it is the O2 after the cat. With the monte there is only 1 bank. Sensor 1 will be closest to the motor. Sensor 2 second out.
Old Sep 14, 2007 | 05:48 PM
GrandPaDave's Avatar
ORIGINAL: TrickRacin
.....on the exhaust under the car right?
Old Sep 17, 2007 | 07:33 AM
wiz kidd's Avatar
sensor 2 is after the convertor, and since there's only one after the convertor it says bank 1
Old Sep 17, 2007 | 09:15 AM
04 Intimidator's Avatar
Look for the big U-Bend in your exhaust behind the cat. It looks like a spark plug with a clip on the top.... until you get a close look at it.
MAMONTE
Feb 18, 2026 09:10 PM
FLMONTESS01
Sep 11, 2010 11:47 AM
Endo
Aug 26, 2010 10:16 AM
The Rev
Oct 19, 2008 09:08 PM
rcohen
Feb 12, 2007 08:49 PM
