Vibration under acceleration???
I was driving down to school, about a 5 hour drive, and I noticed a significant ammount of vibration from it felt like to floor. I need to have the steering knuckle replaced, could that be it??? I think the tires are all balanced, the steering wheel dosent shake much, but I will probabally get that checked.
I only seem to feel it under acceleration, it just feels like the engine is shaking. The steering wheel doesn't vibrate, niether does the brake or gas pedal. I only seem to feel it, when I notice the engine is under powered or like holding back. I believe it's the back pressure from the exhaust, and thats why I'm doing the U-Bend. If i still feel it after that, I'm going to bring it to the dealership to get checked out.
check the tires for balance if your feeling it in the seat of your pants. if you feel it in the wheel it is most of the time in the front wheels. the steering knuckel should not be making it viberate like this. most of the time it just makes noise and really dont effect much just a nusseance.
the down pipe he is talking about will defently open up the out flow of gasses more. and even better after that do teh cat. back system on it to make it flow more.
the thing i have noticed with thease motors is the better they get rid of air the better they run due to the factory system beign so restrickted. So with this said short of spending 1000.00 for a set of headders to have those installed and shipped etc. etc. those two items alone would be the best thing you can do. Also a new hig flow cat will help it sound better and flow better to.
but i dont see where any of this will cause a vibration in the car. i would also check to see if the motor mounts are tight or might be getting wore or lose .
I have also heard of them goign bad if they are the factory ones. but it has been pretty rare.
personally i have been looking in to getting the ones that are polly for the dog bones or if i could find them i would not mind a solid mount to help regain some of the tork loss in the mounts.
good luck and please keep us posted on this.
ORIGINAL: White05LT
you have a point jazz
not to mention keep track of oil changes etc.
they tried to get me on that one becuse they have never done a oil change on the car so they were not going to honnor the warnnety. i happen not to fill ou the log in the back of the owners manual i have always logged them in the puter in a excel file i have set up. so i printed the file and took it out there they shut up when they seen that the recoreds were complet just not done threw a dealer but they wanted to argue it real bad.
I have always been a stickeler for the recipets etc. and details on maintnace. make sure they are kept and from a ase certifieyd mechanic and preferably one from G.M. or trained by them in warrenty work.
If the problem is exhaust related and you have modded it, they will likely use your mod as the fall guy.
It really depends on the dealership and if they even notice the addition.
When at the dealer.............."Don't ask, don't tell" You'll be better off..
i heard one the other day he has gone from teh motor to the tail with 2.5" man it sounds nice. and he changed the muflers out to something else but has the resinator still in there.
I keep going back and fourth on this to leave it in or take it out. I like it loud but want to beabel to drive it with out a head acke also
