Two gauges not working please help
I have a 2004 Earnhadt Jr. edition, the car has just started this crazy problem, the gas tank will be full and the gauge says empty and puts up the fuel light, now this is the wierd part, when that is like that the Temp gauge works normal. Now if the fuel is reading right the Temp guage says the car is running hot in the red, but its not and its not over heating. Has anyone ever had a problem like this? I can't figure out if the guages are bad or the sensors, or something else, no check engine light on either. Any help would be greatly appreciated.
Thanks Rob |
this is a very common problem, the gauge cluster needs replaced! read the attached thread below...
Finally!!! Gauge Cluster Problem Fix!! (https://montecarloforum.com/forum/im.../multipage.gif 1 2 3 ... Last Page) |
I'm not exactly sure if what I posted is correct? I read thru it a little and it may not be the best? look in the search area for your issues. I do know that these gauge cluster do have issues, my friend has an 04 intimidator and he also needed his replaced. I hope you get it resolved.
Thanks,
I figured that the cluster is probably no good its just strange because the car has super low miles |
its deff sounds like the gauges like above (chris) stated
