7th Gen ('06-'07): Transmission Rebuild Kit?
Old May 11, 2017 | 06:37 PM
bdizzleog's Avatar
Default 4T65E - No First Gear
4T65E Transmission - 2006 Monte Carlo LT
1st - Does Not Work
2nd - Works
3rd - Works
Reverse - Works
Drive - Does not work for first gear
Video:
Old May 11, 2017 | 07:08 PM
plumbob's Avatar
Triple Edge Performance. The owner, Dave is a 4T65E Guru and happy to help with technical questions. They'll have everything you need.
Website: 4T65E Parts Store
Old May 12, 2017 | 11:21 AM
x2 on talking to Dave.
But I have heard great things about the Sonnax Sure Cure Kit too.
*edit* it looks like Dave uses Sonnax parts, but offers more complete kits. Definitely just start with him.
Old May 13, 2017 | 09:16 PM
bdizzleog's Avatar
Thank you.
I have uploaded a video of the problem.
Old May 14, 2017 | 08:28 AM
plumbob's Avatar
That's not good! Sounds like a broken "forward apply band", or "first gear apply band". repair means a total rebuild.
Here's a write-up on the symptom from Dave at Triple Edge Performance: 4T65E No Movement D and 3 ranges only
I applaud you for having the guts to take on the rebuild yourself
Here's a great video on the teardown:
Old May 14, 2017 | 11:55 AM
bdizzleog's Avatar
Here's a great video on the teardown: https://www.youtube.com/watch?v=6b8-8FxNvTc
thanks. Now for a rebuild I should replace everything or just the forward apply band?
Old May 14, 2017 | 08:38 PM
plumbob's Avatar
There's several versions of rebuild kits, depending on what you need. Since the forward band is one of the last pieces to come out I would definitely do a full rebuild. I would give Dave with Triple edge Performance a call, explain what you have, any upgrades you might want to do, and he will tell you what you need without ripping you off with overkill.
Triple Edge Performance - Home
