Transmission not shifting right
Old Oct 18, 2017 | 06:19 PM
YoungMonteLS's Avatar
Exclamation Transmission not shifting right
Hi everyone, I recently changed the battery in my car since it died on me and after i installed the new battery the transmission doesn't shift correctly. I figured it might have something to do with the alternator so I replaced that but the problem still persists. I did not have a single issue with the tranny before the battery switch but now if i take it easy going down the road when it shifts at 3000 rpm it stays there for a bit wanting to shift and 2-3 seconds later it shifts. Sorry this is really long I just wanted to give you guys a lot of info.
BTW my car is a 2001 Monte Carlo ls
Old Oct 19, 2017 | 08:22 AM
Is your PCM tuned differently than factory??
My old '02 LS, my current '05 SS, and my bonneville have aftermarket tunes and everytime the battery gets unhooked I need to drive about 100 miles before my shifts feel normal.. I have no idea why this is but have you drove for that long yet? Might just need time to readjust..
Does anyone know why this happens?? I know what hes saying by the whole "2-3 seconds of hang time" between shifts.. Theyre just SOOO soft and take forever. I feel like I need to let off the throttle just from the feel of it.
Old Oct 19, 2017 | 09:08 AM
96z34man's Avatar
Tune or not, all modern electronically-controlled transmissions "learn" the driving habits of their driver and change their shift points accordingly. It's not an instant process. 100 miles sounds about right.
Old Oct 19, 2017 | 03:43 PM
Thats kinda comforting to hear...
Old Oct 19, 2017 | 04:36 PM
No my pcm inst tuned differently from the factory. So the problem will probably go away after 100 miles once the trans "learns" the driving behavior then?
Old Oct 19, 2017 | 08:04 PM
Smile
Another thing to remember is the Service of the Trans Fluid it's good to change that every 50K check it, it should be a red color. If it's brown it should be changed out.
