Transmission Not Shifting Gears
Old Jun 9, 2017 | 11:34 AM
bfoor24's Avatar
Default Transmission Not Shifting Gears
Yesterday my transmission isn't shifting out of low gear. I noticed a feeling of hesitation when I was driving yesterday and then as I was driving I noticed it wasn't shifting. The car has 211,000 miles and the transmission hasn't been serviced in a while unfortunately due to various things. Is there anything anyone recommends?
Thanks
Old Jun 9, 2017 | 02:11 PM
Gonna have to go to a shop. Could be a solenoid, could be hard part failure. But if the trans has 211,000 miles on it, then you are a lucky person!
Old Jun 9, 2017 | 02:23 PM
bfoor24's Avatar
I was getting a code for the solenoid, but it hasn't set the check engine light yet. Thanks for your reply too, you're probably right
Old Jun 10, 2017 | 12:30 PM
bfoor24's Avatar
The fluid is dirty and I've been reading things about dropping the pan and just changing half of the fluid. Maybe that would work? But I'm scared to do that of course with all of the mileage
Old Jun 12, 2017 | 09:03 AM
If it was slipping, I would say yes try the fluid. But you are talking about it refusing to shift, which I don't think would be fluid related unless you are almost out, or way too full.
Old Jun 14, 2017 | 07:57 PM
bfoor24's Avatar
I might try draining a little bit out and see if that changes anything
Old Jun 15, 2017 | 10:15 AM
Pull the dipstick and check the level before you remove anything
Old Jun 17, 2017 | 11:46 PM
claydoh's Avatar
could be the cat? have you ever replaced?
Old Jun 18, 2017 | 05:42 PM
bfoor24's Avatar
I've thought about that after reading other posts. I've had mine replaced about 9 or 10 years ago with the downpipe from zzp. Maybe I should take it to get tested.
